I have setup 8 ethernet ports in Living room and bedrooms during the renovation. Some are spare and will not be used initially. In each room, i plan to connect wire directly to the laptops and also to provide wifi access.
Given that i have it wired up, i believe wired backhaul is better than wireless backhaul. In this case, should i still get the mesh which will act as a wireless access point or get dedicated WAP devices ?
Assuming I am subscribing to Singtel, it means the following :
1. Fibre TP -> ONR (since cannot use own router) -> Unmanaged Switch -> wireless AP device (in each room to provide wireless) -> laptop
OR
1. Fibre TP -> ONR (since cannot use own router) -> Mesh Main unit -> Unmanaged Switch -> mesh node (in each room to provide wireless) -> laptop
Thanks all !
OR
Thanks all !
