Advice on DIY PC
NightRaven49
I just picked something random which is the same brand as the casing which is probably not very good justification. So the reason why you pick the seasonic is that it is cheaper? I think it is $159 vs CM's $169 at Fuwell.
not only is it cheaper but ive also heard it being recommended quite a bit around here. cooler master is more known for its cases rather than psus after all.
RAM - can you elaborate on why you are "apprehensive about getting corsair rams for ryzen"? The G.Skill Trident Z Royal 3600MHz CL16 seems to be $349 though compared to the Corsair Veng Pro RGB 3600MHz CL18 at $269. Any further information to help me decide would be appreciated.
ive heard a few stories of corsair vengeance ram being unable to hit their rated speed on ryzen systems. im unsure if this is the case for vengeance rgb kits though, so do check with the motherboard qvl.
also, do look around more price lists, fuwell isnt the only shop in sls. sometimes there may be other stores selling a certain part at a better price, so do ur research to get the most bang for ur buck.
