Advice on SSD
agent_719
Good afternoon IT geeks,
Im a noob in IT and computer related stuffs. However, im interested to get a 128GB SSD but not sure which brand is good and dunno how to install into the laptop.
I am currently using a Lenovo U330p ultrabook. Checked the other threads it cost around SGD120-140 .
Should i wait till warranty is over then upgrade?
Which retailer / shop provide services to change HDD to SSD and how much does it cost?
On a side track, i would like to change ram too. From 4Gb to 8Gb Amazon.com: Kingston HyperX Blu 8GB (1x8 GB Module) 1600MHz 240-pin DDR3 Non-ECC CL10 Desktop Memory KHX1600C10D3B1/8G: Computers & Accessories
Are all kinds of ram able to work all any processor? and is it better to purchase in SG or from amazon?
My laptop spects are
Haswell 4th gen i5
500Gb HDD with 8 gb SSD ( its called a SSHD)
intel hd graphic card
Normal usage for biz use such as word processing and web browsing.
Thanks in advance and sorry for so many qns.
shadow84
You would need to find laptop rams, not desktop rams...
you can ownself open up the chasis, find your hdd and swap urself. Not worth going to a shop to do it. Up to you to either wait till warranty up or do it now.
What OS are you using?
agent_719
Hi shadow84. Thanks for the reply.
I'm currently using win 8.
Will take note of getting laptop ram. Any recommendations?
shadow84
Win8 64-bit? Im not sure on laptop rams, but it isnt that chim... can go check pricelist. make sure the mhz are the same, and if its ddr2 or ddr3.
Ram prices are on the high, if u can tahan till it drops, it would be good.
shadow84
For 128gb ssd, can consider plextor m5s 128gb at $13x. AFAIK, 128gb ssd not worth to get online since diff is like $10-20 or lesser. Anything above 250gb will have bigger savings.
agent_719
im using win 8 64 bit. how to check ram clock speed and DDR(number)? i go window system only show processor clock speed.
many thanks for the inputs! more comment pls thanks :)
cnt
plextor m5s is goot enuff. google manual on how to open the nb if u not sure :s42:
addamsg
Hello agent_719,
Would like to suggest you for go with strontium brand to SSD and RAM for your ultrabook.
1. 120GB HAWK SSD Drive at US $100
2. DDR3 8GB 1600MHz SODIMM Memory at US $80
watzup_ken
I mean it really depends on your budget for the SSD. Plextor M5 Pro Xtreme is a good drive and at 7mm thickness, it should fit your Ultrabook. Do note some SSDs are 9.5mm thick and likely not be able to fit an Ultrabook. You can check out in Sim Lim from the shop Tradepac. Otherwise, the hybrid drive should be good enough too.
As for ram, first you should check how many ram slots are there for your Ultrabook. Some have 2 and some single slot. Based on your usage pattern, I reckon 4gb might be sufficient. Typically, Windows should soak up about 1.5 to 1.8GB of ram. If you have all those unused software/ games preinstalled by Lenovo, do consider uninstalling them.
AndrikAsh
Haswell 4th gen i5
If you want to install SSD in your laptop, I recommend you to buy the Plextor SSD. The Plextor M5M is a high-performance mSATA 6 Gb/s SSD specifically engineered to give ultra book, tablet PC, and other JEDEC MO-300 form factor users the speed and low power consumption benefits of the newest generation SSD technology.
For more information, please log on to;
Newegg.com - Plextor M5M PX-64M5M mSATA 64GB SATA III MLC Internal Solid State Drive (SSD)
shadow84
1 thing to note though... normal SSD using SATA3 works better than mSATA.. if can get and fit in a normal SSD, then go for it... unless your laptop mobo only supports msata.
agent_719
whats msata and sata? sorry not IT engineered train /:
Guess will just hold my bullet till i have more cash. Now is slowly collecting more info.
Will be installing the prog to check my ram clock speed . btw my laptop have only 1 ram slot.
A thank you to all the bros that have contributed to this thread. Please continue to guide me along. Sorry for my slow reply in this thread too. busy with work haha
circus
I like the crucial website to check for compatible upgrades. It says your laptop has 2 ram slots?
crucial.com/store/listparts.aspx?model=IdeaPad%20U330
SSDLover
I would advise you to go to www.crucial.com to check for all compatibility issues and purchase your parts from there. At least parts suggested from them will work 100%. If not, they refund you.
