Advise on tri screen setup rig
shadow84
Lol, why throw all cables at the front?
Some tips though. For the h100i, remount it the other way. That way, the tubing wun be blocking the 'Corsair' logo. Yours is at left side now, turn it to be at right side.
Why your gpu need 2 seperate cables for power? Shouldnt the x850w come with 1 cable that has dual 6+2 pins?
You want LED, go to SLt lvl 1, got 1 shop sell all LEDs only.
MoneyFace =p
Only if the PCB is jet black :s27:
The cable holes are there to let you poke one.... :s34:
angjds
The cables some too short to route it to the back. Will do the cable management after i get the LED etc.
I will check if i can remount the radiator another way when i get back home.(looks like the RAM may be in the way)
Oh i not sure if the same power cable will be able to channel the huge amount of power so i use separate cable as i see a lot of people using separate cables(maybe its due to those sleeve cable). Ok i will change it.
Thanks for the advise.
Yeah. Dunno want to get red led fan or performance fan.
I did try to poke. Mostly i run it to the back then not long enough. Will do something about it when i get the LED.
royfrosty
The board looks brownish when under a strong source of light. But under normal lightings the brown isnt obvious. And yet still looks black when it is deep in the chassis.
All the wires should be able to route through from the back then to the front. Plab where the wires are suppose to go and slowly adjust. Get a few cable ties.
750D comes with a ssd slot at the back. Can use a single cable that has all the sata power to power your hdd and ssd possible your optical drive also.
Remove one of the hdd cage that you do not need. Remain one will do, allow more airflow in.
As for the fan see if you can get a fan splitter that connects from either one of the 4 pin header to 2/3 fan connectors.
