It is a closed loop so if you need to top up means there is somewhere leaking.Any sexpert?
What problem do you face? Describe symptoms. Car or homeAny sexpert?
Top up will solve the low gas problem but soon it will be low again. You need to find the leakage. Could be cooling coil or any part of the pipe.Any sexpert?
Home, normal servicing then they also check pressure say gas lowWhat problem do you face? Describe symptoms. Car or home
If your compressor is less than 10yrs i don't think so needed. This is a tactics for those aircon contractors to cheat on you easily $60 to $80, don't be a 傻嗨。Any sexpert?
Oic. Monitor for a while. If low again then they will need to trace the leakage.Home, normal servicing then they also check pressure say gas low![]()
Very few compressor can last 10 yrs. Mostly problem comes after 5 to 6 yrs.If your compressor is less than 10yrs i don't think so needed. This is a tactics for those aircon contractors to cheat on you easily $60 to $80, don't be a 傻嗨。
Possible.It is a closed loop so if you need to top up means there is somewhere leaking.
