Air con gas top up is it necessary?
zzzzzzz
me dont service it until it is spoilt because of service men out there who spoiled the market
saved all the servicing money to uninstall reinstall new one when spoil
:frown:
MoeLanYong
If no leak, should run fine. If leak, need to top up air con gas. Can last a long time if no leakage in pipes
Mr Duck
Very few compressor can last 10 yrs. Mostly problem comes after 5 to 6 yrs.
Mine already 11 years. Still cold. Only need to do self servicing bring down the blower and tray to wash, spray aircon acid to clean the coil than later wash away with water, lastly pour 2 bottles of 1.5L water into the tray and use a wet vacuum to sux out all the jelly will do. Every 4 to 6 months clean once.
soarer
Possible if you maintain well and dont use often. But rare.
menthol28
Only when there is a leak then you will need to top up gas but it's better to find out why is it leaking, if not you have to yop up very often. Good working condition AC dun need to top up gas every servicing
Mr Duck
I everyday use. Monday to Sunday master room is 6hrs minimum. Hall is one week twice about 8hrs. So far no problem at all.
Goodshot
only dumb sinkies always aircon top up gas, every 3 month servicing
other aircon using countries laugh at sinkies for wasting money doing unnecessary things
Ya , if a aircon need to service every 3mths , i think can throw away liao
