Mecisteus
- Jun 16, 2002
I just learned about the Sensibo brand. Cut throat price.
I think I will just opt for the Tuya one. Also since I already have other Tuya devices.
I noticed mega discount is cheaper
are their contractor reliable?
Premium Installation Package (Applicable for NEW HDB Installation only)
Installation with 0.5 inch CLASS "0" K-FLEX Insulation (Top grade pipe insulator)
Installation with Grade SWG 22 (0.71mm) copper piping (Thick wall copper pipes)
Installation with uPVC 16mm drainage pipe
Dismantle & dispose old air-con system
1 year workmanship installation warranty
Price stated applies to Standard HDB (Residential) basic installation ONLY, with the standard piping length given. Additional charge applies for longer pipe run.
Price excludes Stainless-Steel Bracket & PowerPoint.
Additional charges apply for private properties, condos & commercial houses due to the size of the house/building & complications of pipe run.
Any other additional work services such as cutting & patching of false ceiling etc are chargeable.
Yeah if 1 sway or alibaba installer but company is reputable, you can sill chase the company.
So so important, but every now and then, someone comes in to save money on installers, aircon compressor, etc.. sighSo don't always go for the cheapest one, sometimes they might be prove to be costlier long term
i think it fan coil dirty. i smell that thing a bit of mold, and metal smellWhy would there be oil on the FCU, which part of the FCU?
My Daikin system 4 already on year 7, still running smoothly.
Update:Sian I think my aircon leaking gas due to Corrosion cause I saw a few drop of oil on the fcu
I wonder how much will how much the repair is or replacement is
My guess if it Corrosion, replaced whole set will be better
did you found any? my previous one also from gain cityAny good aircon installation company to recommend as usually most go will go for GAIN CITY, Courts and Best Denki.
No idea why but the 5 years old hitachi indoor unit when using at Auto Fan and its reduce fan to speed 2 after cooling the room, it will have a howling wind sound until I choose to manually reduce fan speed to fan 1 or increase to fan speed 3 or 4. It’s getting on my nerves, Hitachi Aircon cannot buy.
It’s outdoor compressor also spoilt twice when installed from 2020 till today 2025, lucky bought the extended warranty from gain city, if not gg.
If workmanship is really that bad, it probably would not have lasted 6 years.any reliable installer? I dont want to roll dice with some random stall or retailer. My gain city one leak gas after 6 years. Really not worth to fix it and intent to change the whole system 3.
Suspected is installer nv do properly, the workmanship resulted in the aircon leakage
Don't know leh, I am just fed up.If workmanship is really that bad, it probably would not have lasted 6 years.
So what installer did you previously go with? Can probably avoid lol... Anyway anybody got good lobang for installer, trusted onethat why my last post fear of all these, all these repair add up so much yet cannot fix the issues but already say paid $400 to $500, might as well just replace it, if i know i going to spend that amount to repair a >4yr old system
dm youSo what installer did you previously go with? Can probably avoid lol... Anyway anybody got good lobang for installer, trusted one
