Air conditioning - Any recommendations please??
Zenzoda
Installation went well yesterday with Cold Engine however, woke up this morning and realized the compressor is dripping. Called them up immediately and their Boss told me that is normal coz of condensation. I have requested them to check again this afternoon and will update here again soon.
Dripping could be due to poor insulation at the compressor.
Better to get them fix, else over a period of time the compressor may rust.
wwh5210
I did some researches online and called up Daikin SG yesterday and both provide me with the same feedback. It's normal for compressor to drip a bit due to condensation on those pipes.
carlover76
Can I check what you mean by compressor dripping? Dripping of water from the piping outside of the house near the compressor or the internal piping?
Neogary
Ya, like run a new pipe from another place . Like in front of the wardrobe on the floor. I do not mind the pipe bracket sticking out a bit. Wonder if it is possible.
wwh5210
My compressor is in laundry room and I can see the condensation is from the copper piping which connected to the compressor. It then flows downwards to a hole at the bottom of the compressor. It should be normal right?
carlover76
Yes. That is normal. For my Condenser, it is located outside my bedroom window so I dun see the water dripping but due to the environment heat, piping is cold when the aircon gas pass thru from Condenser to your fancoil, there will be condensation so it is normal.
I thought you are referring to the water dripping from the concealed pipe trunking.
wwh5210
Daikin SG told me the same thing but I'm just wondering should Cold Engine connect a pipe/a tray/or some other thing underneath the compressor so that the water don't anyhow leak?
carlover76
My old Condenser do have a tray and water drainage pipe to toilet and it was done by previous owner's installer. It was a old type of setup and nowadays, nobody fit another tray below the Condenser for the water.
cooldownguy86
I realise that multi-split system i.e. system 2/3/4 is almost non-existent in Malaysia - Malaysians usually have 1 compressor for 1 indoor unit. I wonder why there is a difference in practice, although I know that cost of each system 1 in Malaysia is quite low, about RM1200 for a branded 9k btu non-inverter compressor + indoor unit
Boeing101
So cheap! Really good life over there. Imagine fix 4 in our hdb, SGD1500 at most.
Single split aircon very hard to gg and dont need servicing one.
yang_nastyman
looking for a set of 4 aircon units, one for each room.
previously panasonic was a HUGE disappointment, plagued with problems.
considering mitsubishi, seems quite alright. any comments guys??
endlssorrow
i using Mitsubishi for 5 years. every night on since move in.
so far so good
just done 1 time chemical wash.
carlover76
I have been using Panasonic for many years, using older National then change to Panasonic with the Ioniser function, no major problem but only wear and tear parts need to change.
zhenyuan_2000
Yes, agree. I also requested to use 1/2 inch insulation as well.
Dear all,
I was given this as part of my material insulation during the initial quotation send via email and i got this as offered
- half inch Armaflex class "O" insulation
- G22 copper pipe
- 16mm drainage pvc pipe
however , On the contract (not yet signed)
a) upgrade to half inch thickness class O Armaflex for insulation. { for the copper pipe}
b) upgrade to G22 copper pipe.
c) upgrade to 16mm pvc for drain pipe c/w armaflex class 1 insulation. [1/4 inch]
I am wondering if all these times the 1/2 inch one is talking about is just for copper pipes only OR for both copper and pvc pipes? (i assume the latter)
Hopefully someone can enlighten me
lushiris
same here. i think drainage pipe default is 1/4" (not 3/8" which i typo error)... izit necessary to upgrade to 1/2"?
