ksrokiller
- Nov 17, 2007
is midea popular here? compared to samsung/LG?
If you want get must by 5 years extended warranty to be safe..
Insulation used Kemflex half inch. Copper tube by Natube SWG 21
See budget see sizing see capacity. Both brands are good, so it's all down to your priority. Better electricity saving, or priority on faster cooling?mitsubishi or daikin, for system 4, guys?
Sent from LGE LG-D855 using GAGT
If you want energy saving, then get this. 5 ticks.
http://www.coolserve.com.sg/htmdocs...=3301&prodName='MXY-4G28VA / 4 x MSXY-FJ10VE'
However take note that it's capacity is not sufficient for all 4 to turn on at the same time. (you can, but It'll take longer to cool. Or, on simply don't switch them on at the same time. Wait until one is cool then on the other. Cos the initial cooling phase is the one that requires most energy)
To see other models http://www.coolserve.com.sg/htmdocs/coolAdvisor/cool_advisor.aspx?id=9
In just using it as a gauge. I'm not from coolserve
That's why I go for the LG's 3 tick A4UQ30GFA0 compressor. It's much cheaper than the japanese brand of similar class rating.now this is the F part. the compressor is not able to support 4 fcu at one time, next the compressor are forced to worked harder to generate the same power so the compressor noise is very loud for this model and also i forsee easier breakdown as the fans are made to spin harder for the same juice. more repairs and lesser product life at more expensive price.
i m more inclined to get the 3 ticks as i can see why i will incurred more $ if my aircon is not turned on at lowest temperature but > 25 degrees
thank you for all the feedback guys!
not all 4 aircon will be on at the same time for sure, so i dont think there's an issue.
i think cost is the one that is most impt, other than that there isn't much issue..
for a 150sqm house, to cool all 4 rooms (exclude hall)
priority should be savings, only turned on at night, for 8 hours at most. all 4 units will be turned on for sure without fail.
I don't recommend LG. I have heard from multiple sources that there's quite alot of complaints and malfunctions for LG aircon.That's why I go for the LG's 3 tick A4UQ30GFA0 compressor. It's much cheaper than the japanese brand of similar class rating.
Rated 40K, BTU max.. Comfortably able to support 3 system, with 4 still got some margin..
Do some basic calculation. Get the price difference between a 3 ticks vs 5 ticks model.thank you for all the feedback guys!
Of cos its price is much cheaper than the rest in its category. So that's the catch.
I see. Good luck and hope it's all good for you!Ordered liao. Will see, and keep finger cross. Good thing is it has 5 years warranty on all parts, not just the compressor. So first 5 years there's some comfort there.
