Air conditioning - Any recommendations please??
steven0608
Hi,
Thanks.
BUT after I insert or post link, below are the messages saying :-
"You do not have sufficient post count to post images & links. Please remove the images/links from your message, then you will be able to submit your post"
LouisSaha
hmmm guys , panasonic new envio aircon inverter got such function anot?
like the so called clean function to blow dry ur cooling coil to prevent moulds and fungi being formed... etc etc
chunlianghere
All the inverter unit I see have only up/down but no left/right except MHI.
But MHI made in China so I not sure whether can tahan long.
Can recommend any model you know that hv this left/right feature? Thks!
u mean u got seen b4 all fcu in operation?:s13:
daikin inverter hav..
dkuan88
Daikin Ftkd50/60fvm have this function for left/rite swing.
Ft50/60fvm duh have.
Thks for the info. Will look at it.
But I'm disappointed with some sm that gives wrong info. for whatever reasons.
Consumers like us makes decisions based on their advise.:s11:
oakley
Wow guys.... didn't know there is such a thorough discussion for airconditioning here...
Well I was searching the internet on my insulation till i found this.
The following are my setup bought from Best Tech during the recent Sitex 2009.
LG System 4(Inverter) for $3299.00
  • CU => A4UQ266FA0
  • BED ROOM BLOWER => 3 x AMNC09GD4L0 (9000 BTU)
  • LIVING ROOM BLOWER => 1 x AMNC18GD5L0 (18000 BTU)
  • K-Flex Class 0 Insulation (Not stated size of insulation)
  • 23' grade copper pipe
  • 16mm drain pipe
  • 2 time installation (F.O.C)
  • 36 mths workmanship warranty
  • $200 servicing voucher
  • $100 lighting voucher (can only use $50 for single item max.)
So how?? Good or not??
Abit too late to compare cos I sign liao... but still wanna find out somemore... cos u guys seems like experts :D
Wah no one give feedback??
chunlianghere
  • CU => A4UQ266FA0
  • 16mm drain pipe
i tink its better to find out the thickness of the insulation used.
on the clean function thing, i tink most of inverter hav ba..
steven0608
Hi pal,
I believed all brands are the same as long as they are covered with at least 5 years warranty. Whether the compressor can last a not depend on luck. I have a friend that has a LG that last a couple of years. Some even use Mit electric, kaput in less than a year....
I like Daikin the most BUT just that it's price is one of the highest so :(
Make sure they used at least 1/2" insulator for r410a, ofcause 3/4" is the best :s13:
Copper pipe wise, G23 is ok (said by the installer) but G22 will be the best. Thicker can last longer and harder to have 'kick' during installation. I did copper pipe bending test for G22, G23, G24 pipes while they were doing the installation, each increase in gause made a great difference in strength of the pipes while bending them.
Finally, make sure they use new complete new coils of copper pipe for each fan coil. NO joining of copper pipes if can be avoided.
good luck
vsml
Hi
Just to update on power saving for inverter aircon, my electricity bill is down by 30%......:s12:
Used a non-inverter last time, past 6 weeks using the new inverter aircon. Same usage pattern
RoLanTo
Hi
The MHI aircon you get is a single unit or system 2? may i ask how much u got it?
care to share your usage pattern n bill? :p
Im currently looking for a system 2 aircon for my parents house..
buibuisnail
hi all, wat bout portable air cons?
are they worth buying as compared to normal air con units?
more efficient? cost saving? energy saving? in long run
appreciate e replies :s11::s11:
chunlianghere
any aircon can install...but NOT portable one. unless u got alot of money to pay electricity bills.:s13:
vsml
Mine is a single split. Brought from gain city for 989 with free 5 years extend warranty. Upgrade to 22awg add 20, upgrade to 3/8" armaflex add 20
Usage: 9pm to next morning 9am everyday. Electricity usage alone is down by 30%, i am using electricity usuage not by $ to calculate, cos the price per unit will increase/decrease.
i will monitor for the next few months and update again. Savings could be more
buibuisnail
hi all, me again, forgive my noobness but i've some
questions on how to choose air con.
other than horsepower (BTU) & energy efficiency ration(EER)
what other factors should i consider when selecting air con?
good brands would be daikin, toshiba, wat else? & does color
of piping matter? seems like black is preferred. & if nxt
time for air con maintenance is go back to the manufacturer
correct? if have extended warranty worth it to sign? usually
air con warranty is 1 yr? 3 yr? thanks a lot for answring :s12::s12:
RoLanTo
issit this model SRC25ZG-S / SRK25ZG-S (shown in coolserve)? then 989 is cheaper with 5 yrs extend warranty.
On avg ur monthly bill is agar how much? i just wanna have a rough idea.. cos i dun wan later my parents complain high increment on elect bill.
understand from the previous posts that AWG22 is needed for R410 gas due to pressure, may i ask wats the purpose of upgrade to 3/8" armaflex?
Thanks
chunlianghere
Thanks
default manufacturer recommend is 3/8". but for R410 gas, use 1/2" would be better, as the gas is alot colder than R22 gas. normally upgrading to 1/2" is enough.
chunlianghere
another factor would be total compressor BTU enough for all fcu.
example, sys 3 - 3 x 9000 = 27,000. so if u wan the room to cool faster for all 3 rooms together, than hav to choose compressor which is around 26,000BTU n above.
i guess u mean colour is the insulation. any insulation they provide is ok. gd one is armaflex.
becos all the parts other than compressor is 1 year warranty. so if u scare tat the parts spoil after 1 year,than jus get lor. its all up to u to decide.
ginnah
my samsung air con recently spoilt.
when i turn it on, it just off immediately. the LED light keep flashing. I call samsung service centre, they said the repair work may cost 100-200 + 50 for labour cost.
any recommended technician for repairing the aircon?
