Wtf?
New Bitfenix casings.
Why did they break away from good design?!
Isn't this case just like any other CM casings?
Make so many colors, but none of them are flashy or matching! Grrr...
You find it nice?not matching for you does not mean not matching for others ma.. some colors are quite nice.. and who knows there maybe ppl looking for this type from them.. hahas
You find it nice?
Yeah, sadly, drilling fan mounts on the top of the casing is too hard for such a reputable company.the prob with the bitfenix case is not the looks, but rather the ventilation. the top has no vents for fans.
Actually, the article did state that one single exhaust causes the cpu temps to take longer to go down from under stress to idle. So technically, it is not the best solution. The most balanced one is probably equal number of intake & output, single directional ventilation.PC airflow and heat – a cooling guide « Icrontic
2003 experiment with counterintuitive results
"...A single rear exhaust fan produces the best results overall. This flushes the theory of more is better right out the door..."
so less is really more lol
Please recommend a 140mm intake case fan that's not so noisy.
Adding to the 1 already in the Fractal Design R5.
If you like the quietness of the stock fans, can add the same fan. Will match. Fractal Design GP-14. I added one to my R5.
Yes! Where did you buy from?![]()
Cybermind selling ................
