Air purifier? - Part 2
XinQuan
Hi, does anybody have any review or experience with the Clean Air AP-777 or AP-888? It fits my budget and I suppose it fits my requirements.
I have cats at home but a recent blood test shows I am mainly allergic to cat dander and to a lesser extent, dust mites. I want to buy one AP for my living room and probably 1 or 2 more sets for my bedroom and the bedroom that my baby who is coming soon will be sleeping in.
Appreciate if anyone could advice if the Clean Air APs are good enough or have any affordable recommendations. Thanks!
Akai Ryu
Can anyone help direct where to buy replacement hepa for sharp kc a50e at taobao? Can't seem to find :(
Sent from GAGT using GAGT
MaoZeDuo
Worth to add on? Passion de is their house brand?
batniss
Hi, im looking to get 2 but not sure which one to go for... any tips?
2s imo. want to get, get the latest.
i am thinking should get pro or not since can make use of the current 300-50.
MaoZeDuo
Thanks. I bought 2S and filled up $70 with the green filter and inhouse filter from passion living ($30) instead...
SecretAgent
air purifier users.. does having one at home helps to reduce dust?
Thinking of getting one as my new home gets rather dusty for my likings and needs to be wipe here and there like every 2 days.. Will having an airpurifier reduces dusts?????
Jurong640
Nah. I still gets lots of dust. It might be because I only on air purifier when aircon is turned on, other times, i'll leave the windows open.
zippy79
Not really, is more like filter off harmful super micro dust that you breath in. Big dust still have to clean now and then
watzup_ken
To some extent yes, but generally it is only the area around it. It is not possible for it to suck dust from the air that is too far away as even a vacuum cleaner may not be able to do this too.
dream567
I recently bought a air purifier from indiegogo. I havent receive the item but i hope it works well. the brand name is wynd maybe you can check it out?
Lucky177
Hi, is xiaomi ap 2s and pro using same filters?
Same as in? Not sure 2s default filter comes with the green or blue cylinder type. I only know gen1 comes with the green type whereas gen2 comes with the blue type. (At least previously for my case) I didn't have 2s.
For Pro, comes with the blue one.
"Written before: Just to add on .... although all the 3 types (blue/green/purple cylinder type) of Xiaomi air purifier filters could be used in Pro, if without the RFID "sticker" at the bottom of the filter, error msg will display on the purifier display stating pls use original filter. But still can use.
Take note."
I think 2s should be the same. Not sure.
I only know max is not using the cylinder type. So is not interchangeable if getting the max ap. Correct me if wrong.
