Air purifier? - Part 2
WussRedXLi
If there's a funny smell only first 1 minute of opening and disappear? Plus my air purifier shows green pm2.5 hovering 20 and below would it still be mould??
That probably means a very light mould problem in the AC FCU.
For most of the guys in the DIY Aircon cleaning thread, the standard for most of them there is NO SMELL at all. :D
Very very very low levels of mould spores/particles get blown out of the FCU, i am sure your air purifier or any TB/China based laser particle meters cannot detect that low threshold change when you switch on the Aircon
Or in other words if those laser particle meters can detect, then you would have a much bigger problem of sneezing/coughing/etc due to allergic reactions liao.
ie. Relative to haze PM2.5 levels, this mould triggering allergic reactions threshold is much much lower, many tens to hundreds thousands of times lower.
You might detect a change on the meters that are meant for scientific lab use and costing a few tens of thousands bucks though.
Jimbeam89
I realize the smell is coming from my hitachi EP-A9000 instead of the aircon.. does that mean i should buy new humidification filter??
WussRedXLi
Ditch the humidification filter. Most times it causes more issues than good, coz in Singapore weather it is very difficult for those parts to fully dry out (takes heckloads of time). The same thing goes for those evaporative air coolers. Though in dry climates, they are very easy to fully dry out and so are workable.
I threw out the humidifcation filter of my Sharp KC-840 and cleaned out and scraped clean the water tray with alcohol.
Z_Dash
Needed some guru advice.
For sharp plasmacluster air purifier, any idea if the ionzer function also have a worn out lifespan?
I'm tempted to buy a use plasmacluster and replace new filter, but i guess there is a reason many selling on carousell cheap.
WussRedXLi
From the haze thread.
I think you all can get ready your APs and get additional new filters from TB or qoo10, if you haven't done so liao.
I think this year cannot run away liao, judging from the FFMC and DC maps and hotspot (clusters) on the red areas on the DC map, and also that end Aug to late September would be the peak of the dry season.
Today for Kalimantan
2015 Aug 31 (our Super El nino year with dense and prolonged haze).
We got our first major hit on 10 Sep (PM2.5 269 ug/m3), and 8th and 9th Sep we got 24-hr PM2.5 at > 40 ug/m3 "warnings".
Hotspot Fire Temperature Image (IR)
WussRedXLi
Mine still working leh, 11 years. But anyway, no worries, there's literally no cleaning effect. If you are talking about bacterial/viruses, then maybe....not too sure. Anyway HEPA filter (even the Taobao H10-H11 cheapo generic ones) can filter the droplets that are spewed out from a sneeze/cough. Viruses do not float by themselves in the air.
ipaq4444
That characteristic smell is due to mold re-infestation, when you start to turn on the AC and it comes within 30-60 seconds, and it goes away 5-10 mins away. Same for the car AC.
This is a common issue.
Different pax have different reactions to this.
Your chemical wash done was not sufficient/in depth. I suspect that chemical wash was done with alkaline coil cleaner too. (I was recommending solvent/detergent based cleaners, which are actually milder than the alkaline coil cleaner).
That means you'd need chemical overhaul where the tech would dismantle the coil and every part of the FCU, use alkaline coil cleaner to whack all the parts thoroughly coz everything is exposed, and then flush the caustic alkaline coil cleaner away which is only possible coz everything is exposed. Else any alkaline coil cleaner is left unflushed, those copper pipes and aluminum evaporator coil fins are gonna react and be corroded over time, leading to slow and chronic gas leaks (really $$$ issue). So do engage a proper contactor if you wanna do this, cannot skimp on the cost one.
Also, since the evaporator coil is dismounted, there is always this accidental gas leak risk coz the copper refrigerant pipes are disconnected and reconnected after every time. You cannot do this chemical overhaul too many times, it's too risky and the risk goes up with lousy AC techs who does a lemon job.
Or you need a service provider that can do a very proper and thorough job with solvent/detergent cleaners + regular basis (preferably with high pressure water).
There are vendors offering chemical wash as low as $55, and there are those who charges $90.
And General servicing for $20.
No prizes for guessing.
Learn to DIY lah, with the proper tools and cleaners. Need some small investment in this as well, cannot escape one. Either that or you pay for the services, good ones from good service providers.
Guys! You all got DIY clean your aircon blower ?
https://forums.hardwarezone.com.sg/...diy-clean-your-aircon-blower-5091470-221.html
Can those slow leak be measure using the pressure meter?
Shib
Hi. I had issue to monitor my Mi purifier. I still can control it but just no data. See pic. Let me know if anyone knows how to fix this.
Sent from HUAWEI EVR-L29 using GAGT
free2d
Updated my MiHome to the latest. Now cannot set favorite/manual fan level. Can only Auto, Nite dan Favorite. Also cannot see the filter %. And my car purifier can detect but cannot access. Wonder why onyone?
passingbye
Hi there,
I have a Samsung AX40. Any lobang for replacing the filter as it's not been used for quite a long time.
TIA
Lucky177
I haven’t update to latest. Still at ver 4.21.2 (iphone) ... this one no issue.
Their app sot sot one. Reluctant / hesitate to update if existing version works fine. :(
Shib
I downgraded the Mi Home to 5.5.14. So far so good. You may want to try.
