Air purifier? - Part 2
greythorne
Anyone having trouble to connect to xiaomi home server? Cannot log onto china server and lost control of my air purifier!
I think the air purifier has region. I tried connecting to Singapore region but the psi and pm readings shows as dash line. However connecting to mainland China all the readings can see. Only thing annoying is the message pop up from the store.
WussRedXLi
Vivocity measured at about half of external levels.
Changi Airport (not sure which terminal), some bro measured to be slightly between 1/3rd and 1/2 of external.
Zaalaa
Just changed new filter I bought since few years ago.
For Samsung AX40
But it reduced the airflow & also producing some plasticky smell since last night...
Will tio plastic poisoning in the end? :( I have kids at home... sigh...
stam
is xiaomi AP the most value buy right now? i need to replace 1 of my faulty one
tbs
Ok. Able to use it and set up via hot-spot... So I guess it is the app problem to connect to the router.
ralliart12
For Samsung AX40
What prompted you to change the filter?
acewind
I am using Samsung ax041. When I turn on the purifier, there is power on but it keep blinking at the auto button. The manual say bring to service centre. Any bros know what could be the likely problem? Bought in 2014, think this model obsolete already
vofzxy
Totally black already. Can see almost no space for new dust although still working. So change lo. But the new one plastic smell won’t go away... bought from taobao
you sound worried you bought a dud
i guess i can understand your concern, how much did you spend on it?
Made for Samsung but no brand lor. Qoo10 has one
https://qoo.tn/BRnEgU/Q107272722
$39 after $5 green member coupon and 500 qpoints
these were shared on page 206 207
when i asked and the kind members SIC their findings
maybe quickly get "more proper" one?
nwh_sg
sounds bad. pls sic the taobao link, want to avoid buying from that shop. tks.
nwh_sg
Due to the plastic smell making me nausea... :(
The air filter only. I’m getting new one. Any reliable source?
if urgent, can try the Qoo10 one? so far review seems fine. But more ex. Price is $54. Use $10 coupon and if you have q points, can minus another $5.
edit: link is provided by laeticia, see post #3096 in this thread.
Zaalaa
why not try 3m filtrete?
will take a look at this? 3m filtrete? it seems like it's for Aircon after i google.:s22:
thanks bro, but it still seems like not ORIGINAL. I actually have 2more from taobao coming for AX40 model. so if suay again. i might just buy the original for $70+
laeticia
I just changed filters this week for two of my AX 40. The filters are original Samsung bought in 2015 from Qoo10 korean seller and were sealed in thick black plastic inside the box. No smell or anything despite sitting in my cupboard all these years. The machine works as per usual.
nwh_sg
oh ok. pls kindly review after receiving the taobao filters.
I am using taobao filters bought in 2015 for my LG purifier, don't have the smell issue. Tks.
