Air purifier? - Part 2
sehsuan
Heavy haze, whip out the originals. USe a penknife to cut away the AC (store for future use). Enjoy the 350 m3/hr airflow while being significantly lower in SPL than the XM2 even (388 and 330 m3/hr). :s13:
bro WRX,.. AC = ?
WussRedXLi
bro WRX,.. AC = ?
Activated Charcoal. Just use a penknife to slice, there is sort of a black masking tape that holds the HEPA layer and AC layer together nia. Later just put back together, no need to tape one lah.
testerjp
I ordered
2 XM2
4 AX40
Extra filters should have
AX40 original 3 pieces
XM2 with AC 4 pieces(Taobao)
AX40 RMB29 compatibles 12 pieces
For 2 houses and 1 office.
Office using XM2 cause alot of VOC
Total i think spending $2k :(
Actually normal time still need to switch on AP meh?
Are there reliable compatible XM2 filters?
And for AX40, when then should i switch to the original for the strongest protection? I mean light haze 100-200 still need?
I don't use any yet, but at the moment i think AX40 is a better buy than XM2.
MIVEC525
Xiaomi selling at NTUC got english manual? Mi apps is in english...??
Asakura
whether to on AP during "normal times" is dependable on urself. whether u have severe/sensitive issues.
if u r buying due to the hype of owning an AP during haze period, you wont need it like some people buy liao dont even feel any difference during haze period.
whoooo
Bro I have been trying to slice out the charcoal layer but cant. mine seem to be glued, the filter comes with the Samsung AP. Later i try to upload to see if i done wrongly.
Asakura
if u r aiming xm1
why buy from qoo10 when ntuc give u 1yr warranty?
kandinsky
My family use AP every night, haze or no haze. If you have sensitive sinuses, or if you live near a road, or whatever reason, up to you. For us, we are less likely to wake up with blocked nose. Plus the blowing sound has a bit of white noise machine effect. :s13:
You can always try 1 week with and without, if no perceptible difference, then use only during haze period.
kandinsky
I am also very interested to know what is/are the difference/s?
From looking at the specs compared to AX40H5000GMD, like no/little diff.
Consumption both 34W
Noise both 45db
Size and weight slightly different.
Control strip both exactly the same.
The 2016 model has lower coverage area @ 39.0 sqm, the 2015 has 41sqm.
Using google translate, noticed that they removed one color for the air indicator.
AX40H5000GMD: (Polluted) Red > Orange > Yellow > Green > Blue (Clean)
AX40K3020GWD: (Polluted) Red > Yellow > Green > Blue (Clean)
http://downloadcenter.samsung.com/c...23741788/ACR_JUPITER_IB_DB68-05727A-00_KO.pdf
http://downloadcenter.samsung.com/c...R_JUPITER-QSG_IB_03463B-06_KO_2C_150720-1.pdf
Maybe there's something lost in translation, but based on a cursory look at the specs, if you didn't state which is newer, the AX40H5000GMD actually looks like the upgraded model.
whoooo
Normally how much is an AX40 selling at outside retail shops ah?
Sent from my Rice phone using GAGT
GPGT, let the photo do the talking else pp quote me say i anyhow hamtum, taken last year ard Oct
