Air purifier? - Part 2
lotusnotes
Unfortunately it's only qoo10.sg.
Well Taobao also carries the original Samsung filters, but it's not cheap at about rmb230, so that's like sgd55 shipped if you are tagging on a TB order.
And TB is not really the place that i'd look at to buy original filters anyway.
thank you Master Guru. :)
if it is an original Samsung filter, i would say it is cheap at $55 inclusive shipping as compared with qoo10. Your first sentence makes me happy, then come the cruel part, which is the 2nd sentence :s13:
off topic, TB for xiaomi AP2 filter is authentic right?
WussRedXLi
Where got off-topic one, it's an air purifier thread. Even the haze/El nino thread on EDMW you can also tok about APs. :s13:
Yeah, TB XM2 fitlers are authentic.
Why is it that you hate qoo10? There is a compatibility filter option that is sgd 52 shipped. I haven't measured it (coz i have not bought it in the first place anyway :D ) , but others who bought it described that the make and printing and all details look legit. Should be H13.
testerjp
My original hepa from ax40 stinks within 2 weeks. horrible smell.
Stick to RMB29 is good enough most of the time.
lotusnotes
can order from their official store
Do you mean the XM AP2 filters can get from their official store in TB?
Bro WRX, nope, i don't hate Qoo10, it is the price that makes me look for alternative. the original one cost about $70-75 range. (haha... i know health is the primary concern while $$ can earn back)
the seller for the compatible filter is Goni?
Gd night everybody.. =:p
WussRedXLi
Ok....going to sleep too.
It's this one. 52 dollars shipped for ax40 ver.
Just to let folks here know:
I just received my AX40 compatible replacement filter. It look, feel and fit exactly the same as Samsung original filter, and from the visual/audeo observation, the airflow from high speed fan setting is the same.
When I said look exactly the same, I meant EXACTLY. From the AC layer, side foam sealing tape, printing on side of filter, folds and reinforcement etc, all the same. It looks like the OEM version for me.
The only difference fr Samsung original filter is, it come in non-colored external box and in a clear plastic bag (see the picture in the review of the following q10 link). The original one come in a colored boxed with Samsung printed on it, and the plastic bag is a better quality black plastic bag. But all these do not matter.
http://list.qoo10.sg/item/SAMSUNG-AIR-PURIFIER-REPLACEMENT/442622329#none
whoooo
can I ask where to get filter for AX40H5000GMD other than qoo10.sg? kindly PM me pls. i want original because I am lousy at DIYing filters. thank you so much..
think afew of us bought from this seller on TB, I think was intro by Wuss during last year sky high haze period, i just bought 2 this week and shld received on Monday
https://world.taobao.com/item/522668837488.htm
whoooo
How to rectify/reset if the AX40 suddenly goes into this mode? Up lorry already?
https://www.youtube.com/watch?v=0aZNn3JXh1M
say please den I help you. :s13::D
joking try this
1) Unplug the purifier,
2) Connect the plug,
3) press Menu button + Lock looking button for 3 seconds (it will make a "ting" sound),
4) Press Menu button + power button for 3 seconds (it will make a "ting" sound),
Thats your option set.
5) Unplug your purifier and connect, it will work normally.
MIVEC525
joking try this
Menu botton is the many square?
kandinsky
2nd button from left.
wkweksl
joking try this
Wow, that worked, thanks bro!
lotusnotes
Buying from Qoo10 global experience.
Any difference in terms of buying from Qoo10.sg vs Qoo10 global? TIA again
WussRedXLi
anyone bought from taobao via Global Direct Shipping? ¥61.00 only?
Absolutely do not do that. Do a search. For some items like these, the 圆通 warehouse will just reject it flat out when it reaches Shanghai, and you would not have an option to do anything. None at all. They will do nothing, not even if you offer them extra money.
People's 豹米 and other APs have been rejected, and you'd need to arrange to return to seller with a refund + deduction for service/re-stocking/shipping costs.
IAmZTX
Anyone got any recommendation for dehumidifier with hepa? Budget 50 to 100. Most important is the noise level. Silent if possible.
Usually close my door at night to study or sleep and feel humid all the time.. windows is closed most of the time
cnotsniw
QUOTE=WussRedXLi;100838244]Absolutely do not do that. Do a search. For some items like these, the 圆通 warehouse will just reject it flat out when it reaches Shanghai, and you would not have an option to do anything. None at all. They will do nothing, not even if you offer them extra money.
People's 豹米 and other APs have been rejected, and you'd need to arrange to return to seller with a refund + deduction for service/re-stocking/shipping costs.[/QUOTE]
Bought my TB filters via Global Direct Shipping before - no issue.
But during 10/10 event, 1 item was rejected (car windows rain shield) due to too bulky. Luckily, seller refunded 100% but suffered forex loss. The other issue was very late delivery due to the 10/10 rush.
