Air purifier?
WussRedXLi
S$399 and free 1 HEPA filter
http://list.qoo10.sg/item/CNY-CRAZY-SALE-NEVER-AGAIN-PREMIUM/421450063
Number 1 CADR rated air purifier in the market
Clean Air Delivery Rate: US AHAM standard: 282.2CFM (USA PM 0.1um), tested in USA.
Europe CADR standard: 481 m3/h(EU PM 0.3um and PM 2.5)
True HEPA from Korea with 99.97% filtration rate, biggest HEPA filter size
Japanese tooling and quality control level
Malaysian Bamboo Activated Charcoal Carbon ensures 90% removal rate of odors and Volatile Organic Compounds
Japanese motor for strong airflow and long lifetime
Highest quality Ultraviolet Germicidal Hospital Grade lamp ensures 99% bacterial removal
Tested in USA by InterTek and Guardian
6 Purification levels: Pre-filter + True HEPA + Activated Carbon+ PCO +UVC + Ionizer
Ultraviolet germicidal lamp and Ionizer can be switched On and Off at sensor control panel
Specifications:
99.97% Efficiency TRUE HEPA Filter + Activated Carbon Filter + Ultraviolet germicide lamp + Photocatalytic Filter + Negative Ion Plasma
• Product size: 445(L) x 238 (W) x 680 (H) mm
• HEPA filter: 358 (L) x 435(W) x 25 (D) mm(Made in Korea)
• Unit Power: max 72W
• UVC power: 4W
• Noise level: 29dB( Low), 45 dB(Medium), 58 dB (High)
Applicable area: up to 60-80 Square meters
1 year Singapore Warranty
WussRedXLi
New data found.
Rainfall anomaly.
Very telling leh.
And also average rainfall.
See western Kalimantan and the part of Sumatra that's below SG's latitude.
WussRedXLi
http://www.bmkg.go.id/BMKG_Pusat/Kualitas_Udara/Informasi_Partikulat.bmkg
PM10.
But in my experience of checking our PM10 and PM2.5, for Indonesian haze and at this distance, PM2.5 and PM10 are around the same level. Perhaps for Pekanbaru, PM10 is at a slightly higher level than PM2.5
PEKANBARU, Jam 5 : 302.15
PEKANBARU, Jam 6 : 379.83
PEKANBARU, Jam 7 : 327.73
PEKANBARU, Jam 8 : 270.00
Read more: http://www.bmkg.go.id/BMKG_Pusat/Kualitas_Udara/Informasi_Partikulat.bmkg#ixzz3h5aSGrNd
AQI of 236 (based on PM10)
400 ug/m3 of PM10
Indonland only has PM10.
For NEA, we don't have hourly PM10, but we have hourly PM2.5
Thailand in March.
PM10 and PM2.5. Both track quite closely, with PM2.5 a hair behind.
So far so good, SE to SSE direction.
No Low Pressure Area, Tropical Depression, Tropical Storm, Typhoon in the South China Sea or Philippines area to change the wind dir.
Today 28 Jul 2015 PM10.
PALEMBANG, Jam 4 : 8.90
PALEMBANG, Jam 5 : 6.77
PALEMBANG, Jam 6 : 8.00
PALEMBANG, Jam 7 : 27.07
PALEMBANG, Jam 8 : 103.42
PALEMBANG, Jam 9 : 175.81
PALEMBANG, Jam 10 : 192.85
PALEMBANG, Jam 11 : 191.06
PALEMBANG, Jam 12 : 178.77
PEKANBARU, Jam 0 : 127.09
PEKANBARU, Jam 1 : 138.52
PEKANBARU, Jam 2 : 159.03
PEKANBARU, Jam 3 : 165.95
PEKANBARU, Jam 4 : 152.52
PEKANBARU, Jam 5 : 153.37
PEKANBARU, Jam 6 : 174.53
PEKANBARU, Jam 7 : 208.27
PEKANBARU, Jam 8 : 251.54
PEKANBARU, Jam 9 : 259.09
PEKANBARU, Jam 10 : 272.24
PEKANBARU, Jam 11 : 264.24
PEKANBARU, Jam 12 : 240.48
stam
Specifications:
• UVC power: 4W
Hi WussRedXLi,
Is this good compare to the samung A40?
WussRedXLi
Hi WussRedXLi,
In medium mode, it seems to be as loud as the AX40 at 45dbA for both. AX40 is 323m3/hr but no mention for this device.
Wattage 72W at 481m3/hr. Jap motor and electronics. Decent consumption same as Sharp A80. A80 $475 cheapest and no foc extra filter and no delivery, but Sharp reliability (talking abt APs and not other lines).
Filter could be v big if you next time wanna try taobao customised filters with 45mm thickness. Local agent carries the original filters but not sure abt the price. Own choice.
36cm x 43cm area and 25mm depth, i assume if dont use the AC and photocatalytic filter i can squeeze on 20mm more.
The LG filter is 36x34cm. Samsung 31x28cm. Bigger than all the Sharps.
They tested it down to pm0.1. Made in korea HEPA.
For 399 w free filter and free delivery and 1 yr local warranty, can consider if you need that power + sensitive to noise (use medium speed in MBR during sleeping). Decent price performance ratio.
481 m3/hr barely enough for living room + MBR with 1 x fan. to aid circulation, shd work for sensitive folks like infants up till ard 200 ug/m3 external. Medium speed more than enough for MBR.
WussRedXLi
Seems like they are using quite good quality surgical mask. There is a bypass of approx 30-40% at the sides, can prevent by scotch-taping the 2 sides and bottom to your face I guess.
(medical personnel at TTSH during SARS did this with their N95 respirators as a max precaution measure as the respirators may shift during work procedures)
They cannot distribute respirators to the public. Cost too much, even for say the Chinese KN90s.
chuanz
I think during the 2013 haze somebody somewhere documented that even with cotton cloth (maybe moist, I can't remember) you can reduce the amount of particles inhaled. Of course, it's not ideal but it still cuts it down (if worn properly).
Edit: Found it http://www.purelivingchina.com/2013...ion-face-masks-what-is-the-right-fit-for-you/
WussRedXLi
Unfortunately, the bypass of the surgical mask on the face is about 1/3.
So that's an additional of ~ 65 ug/m3 of pure outside air added to the 81 ug/m3.
http://www.cidrap.umn.edu/news-pers...y-supports-use-n95-respirators-flu-protection
"A poorly fitted respirator or a loose-fitting surgical mask, by contrast, blocked only about two thirds of the virus particles."
PS. I made a mistake, totobobo testing used a 0.5 micron and 2.5 micron laser particle counter. Not the other version with 2.5 and 10 microns. Edited above.
stam
Hi all,
Any simple air quality meter that can be bought on taobao to intro?
WussRedXLi
Hi all,
Why not refer to Chuanz's website, data taken from NEA?
If you have money to burn and have a real need for it (elderly parents, infants, asthmatic children hence short term spikes matter) :
https://item.taobao.com/item.htm?spm=a1z09.2.9.111.mRDdG0&id=43721215547&_u=s1u0hcibdd63
This guy's version is better, slightly more ex. Chuanz bought from him before, shd be legit. However, he was damn slow in answering my ALWW messages, like he super part time like that.
https://item.taobao.com/item.htm?spm=a1z0d.6639537.1997196601.271.jzkdfr&id=45505826310
PS. Asthmatic children, well....my kids are fine. But SG medical is super ex during emergencies.
Oon Hari Raya the youngest one had vomitting issues despite giving anti-vomit medication via suppository (rectal) so these things cannot play. Went to Clementi Central 24-hr clinic costed me SGD121...$80 consultation and the rest are meds :s22: Previously on a Saturday evening, it costed me SGD80 ($50 consultation, rest meds).
I can't help it when the neighbourhood clinic is closed (usually 40-50 dollars).
And 1 time I kena before, super emergency, S$900 at Mount E. Spec called in, plus some bedtime at the A&E. SGH could not handle, 4hr wait.
WussRedXLi
http://onlinelibrary.wiley.com/doi/10.1029/2005JD006180/pdf
Size distribution of the particle size, mass concentration and number of particles on hazy and clear days.
Looks like for PM2.5, majority of it is between 0.2 to 1 micron peaking at 0.4-0.5 microns. There is a second peak at 3 microns.
So your mask must be able to handle that range.
The study also measures ultra fine particles and nano particles, but is thought to contribute negligibly to the overall air quality pic when we talk about haze.
"Besides the mass concentration, measurements of the
number of ambient particles are also of special importance
in the final assessment of potential health effects. Despite
significant damage to human health, the small particles
including NPs and UFPs add negligibly to the overall mass
loading of PM2.5 and PM10 although their numbers may be
much greater [Tuch et al., 1997; Keywood et al., 1999], and
hence do not play a major role in the conventional ambient
air quality standards. Therefore, in addition to the monitoring
of the PM2.5 mass concentration, it is also useful to
investigate the number concentration and size distribution
of NPs and UFPs."
plasticpistola
Post H12/H13 exhaust filter (3M Filtrete HEPA), @ max power.
So yes, it does filter like a good air purifier. The performance is excellent.
Question : (1) Do you need this kind of performance?
(2) Can you afford the vacuum cleaner, and after that can you afford the yearly costs?
ie 3M Filtrete = usd 9 per year. usd 8.99 main bags (3 mths change, 3X weekly vacuums)
Bro your vac is Philips brand?
Every now n then I'll wake up with sh*tty arse headaches that can last through the day or even for 2 straights days.
GP says its just tension headache but I think it could also be allergy cos it always comes with blocked nose :vijayadmin:
ac serviced every 6 mths~
WussRedXLi
Yes it is Philips (FC9166).
If its allergy suspicion, then you would need to try AP during sleep time and also keeping your bedsheets very clean. Try to get anti-allergy sheets and pillow cases as they have a pore size of 5 microns or less....so it keeps mite populations and feaces allergens at the surface or inside below the surface.
yanbros
Where to find such sheets? Care to share? Thanks.
WussRedXLi
OG metro robinsons all have. Either sheets or the whole pillow itself. Later i go check. Get back by 1pm.
Got brands like Nature Guard, King Koil. Matress protector queen size $139 before disc. Probably creates a barrier from the mattress and mite population/feaces allergen (vacuum the mattress properly before putting that on). Also got. Anti mites pillows $50 and duvets etc.
Less than 10 microns weave = impermeable to the mites and dropping allergens.
Can dander is worse, if got cat...its Ig allergen is way more potent and 25% is below pm2.5 so it can stay in the air for very long.
WussRedXLi
http://www.health.state.mn.us/divs/eh/indoorair/voc/
Volatile Organic Compounds in Your Home
Volatile Organic Compounds (VOCs) are a large group of carbon-based chemicals that easily evaporate at room temperature. While most people can smell high levels of some VOCs, other VOCs have no odor. Odor does not indicate the level of risk from inhalation of this group of chemicals. There are thousands of different VOCs produced and used in our daily lives. Some common examples include:
Acetone
Benzene
Ethylene glycol
Formaldehyde
Methylene chloride
Perchloroethylene
Toluene
Xylene
1,3-butadiene
Where do VOCs come from?
Many products we have in our homes release or “off-gas” VOCs. Some examples of sources of VOCs are:
Building Materials
Carpets and adhesives
Composite wood products
Paints
Sealing caulks
Solvents
Upholstery fabrics
Varnishes
Vinyl Floors
Home and Personal Care Products
Air fresheners
Air cleaners that produce ozone
Cleaning and disinfecting chemicals
Cosmetics
Fuel oil, gasoline
Moth balls
Vehicle exhaust running a car in an attached garage
Behaviors
Cooking
Dry cleaning
Hobbies
Newspapers
Non-electric space heaters
Photocopiers
Smoking
Stored paints and chemicals
Wood burning stoves
Studies have shown that the level of VOCs indoors is generally two to five times higher than the level of VOC’s outdoors. VOC concentrations in indoor air depend on many factors, including the:
Amount of VOCs in a product;
Rate at which the VOCs are released;
Volume of the air in the room/building;
Ventilation rate or the area; and
Outdoor concentrations of VOCs.
What are the health effects of VOC exposure?
The risk of health effects from inhaling any chemical depends on how much is in the air, how long and how often a person breathes it in. Scientists look at short-term (acute) exposures as hours to days or long-term (chronic) exposures as years to even lifetime.
Breathing low levels of VOCs for long periods of time may increase some people’s risk of health problems. Several studies suggest that exposure to VOCs may make symptoms worse in people who have asthma or are particularly sensitive to chemicals. These are much different exposures than occupational exposures to VOCs.
VOCs refer to a group of chemicals. Each chemical has its own toxicity and potential for causing different health effects. Common symptoms of exposure to VOCs include:
Short-Term (Acute) to high levels of VOCs
Eye, nose and throat irritation
Headaches
Nausea / Vomiting
Dizziness
Worsening of asthma symptoms
Long-Term (Chronic) to high levels of VOCs
Increased risk of:
Cancer
Liver damage
Kidney damage
Central Nervous System damage
What levels of VOCs is safe?
The best health protection measure is to limit your exposure to products and materials that contain VOCs when possible. If you think you may be having health problems caused by VOCs, try reducing levels in your home. If symptoms persist, consult with your doctor to rule out other serious health conditions that may have similar symptoms.
MDH has established Health Risk Values (HRVs) for some individual VOCs. HRVs are “concentrations of chemicals or defined mixtures of chemicals emitted to air that are unlikely to pose a significant risk of harmful effects when humans are exposed to those concentrations over a specified time.”
For more information on these HRVs go to MDH Health Risk Values website.
Also check the Household Products Database website.
Most health related studies have been conducted on single chemicals. Less is known about the health effects of exposure to combinations of chemicals. Because the toxicity of a VOC varies for each individual chemical, there are no Minnesota or federal health-based standards for VOCs as a group.
Are some people at greater risk from VOC exposure than others?
Persons with respiratory problems such as asthma, young children, elderly, and persons with heightened sensitivity to chemicals may be more susceptible to irritation and illness from VOCs.
What can I do about VOCs that are in my home?
Although home screening kits (devices) are available to measure total volatile organic compound (TVOC) levels they are of limited use and won’t correct a VOC problem. Instead of testing, the first step is to conduct an inspection of your home for the common sources of VOCs. Sources that may be problematic include household furnishings which tend to off-gas more VOC’s when they are new. Possible sources include carpet, furniture, paint, plastics or electronic devices.
Once you determine the probable source(s) of VOCs, steps can be taken to reduce your exposure. If you are unable to determine probable sources, a professional indoor air quality investigator or an industrial hygienist can be consulted. MDH has developed a document, "Guidelines for Selecting an IAQ Consultant."
How do I reduce the levels of VOCs in my home?
The most effective action is to remove the product that gives off VOCs. Most products containing VOCs will off-gas within a short period of time, although some will continue to give off VOCs for a longer period of time.
Some steps you can take to reduce your exposure to VOCs in the home are:
1. Source control: Remove or reduce the number of products in your home that give off VOCs. Only purchase amounts of chemicals that you know you will use and carefully follow directions on product labels. Remove unused chemicals from the home because stored chemicals in closed containers can sometimes “leak” and release VOCs into indoor air. Check with the city or county for household hazardous waste collection sites.
For new items consider purchasing:
floor models that have been allowed to off-gas in the store
solid wood items with low emitting finishes
new products that contain low or no VOCs (environmentally preferable products)
As a last resort, airtight sealers have been used to minimize VOC emissions. Check with vendors of composite wood products to choose a non-toxic sealant to reduce exposure to VOCs.
2. Ventilation and climate control can be used to reduce exposure to VOCs.
Increase ventilation by opening doors and windows, use fans, maximize air brought in from outside;
Keep both the temperature and relative humidity as low as possible or comfortable. Chemicals will off-gas more under warmer conditions with high humidity; and
If you have a choice, perform renovations when home is unoccupied or during seasons that will allow for additional ventilation.
In summary, the most effective way to limit VOCs indoors is to limit the potential sources of VOCs. Increasing the amount of outdoor “fresh air” into a space can also dilute and reduce VOC levels.
WussRedXLi
TVOC Symptoms
< 200 µg/m3 No irritation or discomfort expected
200 – 3,000 µg/m3 Irritation and discomfort may be possible
3,000 – 25,000 µg/m3 Discomfort expected and headache possible
> 25,000 µg/m3 Toxic range where other neurotoxic effects may occur
Source from Aerias
