Air purifier?
asiafrenz
anyone here already measured the hepa filter size for the Samsung AX40?
would like to get a customised filter from taobao instead of getting the original so that can change more often.
also, any recommended taobao site to get reliable and good workmanship of customised hepa filter?
thank you in advance.
laeticia
OK thanks.. means it's the same as those EU round 2 pin. I jammed it also.
Means no need to get the converter liao
I prefer to use an adaptor cos I have been moving mine around...it's slightly thicker than our 2 pin plug, bring to Korea can use but the reverse cannot
eurofunk
u getting from which store? :s12:
ever joint, wanted to get the 2 sets but another one reserved and last pc
at least this week peace of mind
Akai Ryu
KCA 50 was the good thing.
So wasted
ok lah since its an extra of mine and buyer buying for baby....i prioritize change of filter...older filter goes to less often use ap in my study....ap with older filter i just use even with windows open at times
Millimeter
Need some help here.
My father has lung problems and the haze is affecting him. So I need to buy an air purifier, but the local stores seem to be out of stock. Saw this seller online: http://list.qoo10.sg/item/SAMSUNG-ELECTRONICS-FREE-3M-N95-MASK-SAMSUNG-LG-BEST/410986590
Thinking of getting the Samsung AX40 or the LG that covers 41 sqm. Any suggestions or tips on buying the air purifiers?
Of course if you know somewhere to buy air purifiers this weekend it would be best!
otacon
Heard AX40 is well recommended but not familiar with it. Trying to find out more too
kimsim
Suspended
Just my short review after 1st for few hours only.
This sharp KCA-40EB comes with Humidify function can help up room clean air with added cooling on room temperature as well, the airflow without noise at all, when 1st run got slighly charcoal smell, after an hour no more smell already, for a whole room feels much fresh now.
That is worth it.
At the back after pre-filter I had applied Daiso gas filter, can reduce the dust get into hepa, hope it helpful to created longer life.
eurofunk
anyone know if can just get cheaper replacement filters for standby for the sharp kcd60?
Akai Ryu
D60's charcoal filter cannot be washed right? looks similar to Novita's which has 24 month effective use. But Hepa most impt
I lost my KCA50 seller at TB....left 6 extra set of filters only :(
eurofunk
Can't Rem the guy saying something like the black filter just need to vacuum if need to clean, then the hepa will last a yr or something...can't Rem if it's the other way round
