Air purifier?
NWT1978
you also buying Air+? I find the plastic cover for the value (if not using the respirator) quite easy to drop and get lost. Pro is that its easier to wear and take off
nah just to give info to others whom want it... I using the N95 masks... need to wait for stock to use up then get the uvex ffp2 from Taobao... look more comfortable and cheaper than buying locally :s12:
Nintendou
Got this model yesterday... So far so good....
How is the dust sensor? Mine is green all the way even with sensitivity turned up for the past few days. Only changes color for a while when I stand behind it. Removing the square piece of sponge covering it doesn't seem to have much effect as well.
Any other sharp users in the same situation?
purpleberry
Teardown review of AX40
Well, not really a teardown, wasn't really necessary, all I did was take out the filter to expose the fan motor.
The fan motor is a 310V DC brushless motor from 日本电产芝浦(浙江)有限公司。
So...sounds like a tiong company, eh? A quick googling turns up a real surprise:
Parent company is 日本电产...also known as Nidec Corp...
Wait...what?
Nidec? THE Nidec???:eek:
PC enthusiasts may be familiar with this brand...many popular and well reviewed PC cooling fans uses Nidec motors. In fact, I first got to know of this brand during my DIY PC days.
Nidec, a Japanese company, is the industry leader in fan motors.
So, the AX40 uses a brand name Japanese motor of (possibly) Japanese design, made in China.
I also separated the charcoal filter from the HEPA. It's quite easy, just need a penknife to carefully cut along the black masking tape, along the seam. just becareful not to cut the grey foam. Both sides of the charcoal screen have the same netting.
Since activated charcoal lasts about 1-3 months, u either remove it completely, or somehow replace the charcoal granules.
If u don't mind doing a bit of DIY, u can cut open the netting on one side, replace the charcoal granules (very cheap from Taobao, Qoo10, even Daiso), then sew up the netting. I guess the most time consuming part is the sewing, lol.
I think Samsung has a winning product here...brand name motor, quiet, efficient, plasma ionizer on/off, high CADR, 5 color led indicator, possibility of cheap replacement of charcoal filter, cheap HEPA alternatives from Taobao...best of all, great prices from qoo10!
If Samsung were to improve this product, I hope they give a nano silver anti bacterial coating to the filters...similar to Winix.
Hope u guys find this review useful!
Edit: fan motor label shows 31W, not the 34W indicated by Samsung.
This explains the sub 30W reading taken by bro WRX
Wow NIDEC?!?! That should put it in the brochure!
Asakura
normal consumer u tell them nidec u think they know?
"simi lai eh? nitec?"
Akai Ryu
sold one of my kca50 ytd.....buyer asked y no haze mode.......sigh.............spent 10min educating buyer on basic ap function and that such terms are marketing gimmicks.....
Akai Ryu
really got work or uses?
gonna put some on AC vent...mb ap too...the rest in cabinet i guess....the ones i purchase come with some tester kit...mb will try test test...
just got email fr forwarder that cannot come by air....hope ok by sensitive air else 2 weeks by sea
WussRedXLi
Wait...what?
Thanks for the write up. Posted similar stuff last time, think in May or June 2014 before the 2014 season. :s13::D
Coz folks were scared about the 220V thingie......50Hz an 60Hz cycle freq.
etc
Naked peektures!!
kimsim
Suspended
KCA 50 was the good thing.
So wasted
derazor
the samseng KR version... the plug they give is it the 2pin plug? This type can "force" into the multiple socket?
