Air purifier?
kimsim
Suspended
Added my name to the list too. Thanks!
Seller : http://world.taobao.com/item/2333928...4.12193480.0.0
filter for Samsung AX40
kimsimx1 (Helping to order)
ralliart_ray x1
derazor x1
john doe 84 x2
defytherules x2
JoePilot x2
filter for Sharp
Sharp 180 机 HEPA @ thickness 35mm
derazor x 2pc
RalliFTO x 1pc
NOTE:
Cut of date at 4/10/15 (12pm)
We process place order by 5/10/15 morning :D
(IF you guys think for cancel and make sure before 12pm of 4/1/15)
For samsung AX40
For Sharp 180Model (Not too sure they able for customise)
DIY 300x300x25mm
Renzokukenz
If you're on a low budget, and don't care about aesthetics consider the SmartAir method - Buy some HEPA filters off taobao and strap it to regular fans.
Basically, this guy figured out and tested that a HEPA filter strapped to a box fan can work pretty well on a tight budget.
http://qz.com/112173/a-grad-student...ld-help-chinese-city-dwellers-breathe-easier/
http://smartairfilters.com/en
http://particlecounting.tumblr.com/
https://shop106566697.world.taobao.com/?spm=a312a.7728556.2015080705.4.IS77sg
NUS developed version:
http://airazor.com.sg/en/home/16-fan-converter-set-16-blade-18-frame.html
http://news.nus.edu.sg/highlights/7720-cost-effective-solution-that-leverages-fans-as-air-purifiers
yes the NUS developed ones are the best
i actually shared it on my own Facebook before coming here
problem is that I use a tower fan and they cant be retro-fitted
But for anyone else please do consider this NUS developed filter
$80 and turn your normal fans into an instant purifier
JoePilot
Added my name to the list too. Thanks bro kimsim!
ralliart_ray x1
derazor x1
john doe 84 x2
defytherules x2
JoePilot x2 (310mm x 281mm x 45mm)
filter for Sharp
derazor x 2pc
RalliFTO x 1pc
ralliart_ray
ralliart_ray x1
derazor x1
john doe 84 x2
defytherules x2
filter for Sharp
derazor x 2pc
RalliFTO x 1pc
Have to be tactical if wanna siam the $400 gst threshold (if any)
NWT1978
NOTE:
For samsung AX40
DIY 300x300x25mm
yes same seller able to do it for Sharp 180.
Just inform him through the blue guy or gal... he cut or customerise for u... it same seller but different product being displayed?
your screenshot did not displayed the Sharp 180...
linusz
kimsim
Suspended
180 couldn't find in the list.
From Wuss bro said is similar to 280 model
For those customise size still pay your own risk, when order is right, once receive wouldn't exactly the same.
If you guys know the link can provide here
martintylor
Added my name to the list too. Many thanks bro kimsim!
ralliart_ray x1
derazor x1
john doe 84 x2
defytherules x2
filter for Sharp
derazor x 2pc
RalliFTO x 1pc
DIY 300x300x25mm (no edge)
martintylor x 2pc
NWT1978
http://world.taobao.com/item/23339280327.htm?fromSite=main&spm=2014.12193480.0.0
got mine here... but since do the customisation can ignore to select for the type lol =:p
prices seem went up... :( guess only seller :( where the good solid competitive that able to have similar or better quality products at TB :(
JadziaK
Added my name to the list too. Many thanks bro kimsim! :)
ralliart_ray x1
derazor x1
john doe 84 x2
defytherules x2
JadziaK x 2
filter for Sharp
derazor x 2pc
RalliFTO x 1pc
martintylor x 2pc
linusz
ralliart_ray x1
derazor x1
john doe 84 x2
defytherules x2
JadziaK x 2
Linusz x 2
filter for Sharp
derazor x 2pc
RalliFTO x 1pc
martintylor x 2pc
kimsim
Suspended
[uErl]http://world.taobao.com/item/23339280327.htm?fromSite=main&spm=2014.12193480.0.0[/url]
How bout this
http://m.intl.taobao.com/detail/detail.html?spm=a1z5f.7632052.0.0&id=39888011864
derazor
derazor
ralliart_ray x1
derazor x1 (310mm x 281mm x 45mm)
john doe 84 x2
defytherules x2
JadziaK x 2
Linusz x 2
filter for Sharp
derazor x 2pc
RalliFTO x 1pc
martintylor x 2pc
derazor
Ya the seller not around, maybe still under holiday.
Will try to quote him for customise size.
Thanks bro. I suggest the AX40 all go for customize ( less hassle and better performance at a fraction of the cost ) and also take note of GST also. May need to split 2 orders or something...
