Air purifier?
kimsim
Suspended
kimsim
Suspended
Thanks bro. I suggest the AX40 all go for customize ( less hassle and better performance at a fraction of the cost ) and also take note of GST also. May need to split 2 orders or something...
Split order still will meet up, I will try for 2 different name and place to delivery address too.
Asure7
Seller : http://world.taobao.com/item/2333928...4.12193480.0.0
filter for Samsung AX40
kimsimx1 (Helping to order)
ralliart_ray x1
derazor x1 (310mm x 281mm x 45mm)
john doe 84 x2
defytherules x2
JoePilot x2 (310mm x 281mm x 45mm)
JadziaK x 2
Linusz x 2
Asure7 x 1
filter for Sharp
Sharp 180 机 HEPA @ thickness 35mm
derazor x 2pc
RalliFTO x 1pc
DIY 300x300x25mm (no edge)
martintylor x 2pc
Mach3.2
ralliart_ray x1
john doe 84 x2
defytherules x2
JadziaK x 2
Linusz x 2
filter for Sharp
derazor x 2pc
RalliFTO x 1pc
martintylor x 2pc
ax40 no need to alww the seller liao, there's a page for it.
http://world.taobao.com/item/522668837488.htm?spm=a312a.7700714.0.0.d4JaZN#detail
aCidz
kimsim, if you are shipping through 4px etc, take note of the package size restrictions of the forwarders.
idiots
Wss korkor, what about replacement filter for Sharp KC-A40E, HEPA filter FZ-A40HFE, 370mm x 234mm x 32mm?
joelhaw
Anyone ordered ax40 from Rakuten Goni on 29/9 and the status is still awaiting shipment but has the tracking no.? Anyone has the status changed? Thanks.
meesoto
ralliart_ray x1
john doe 84 x2
defytherules x2
JadziaK x 2
Linusz x 2
Asure7 x 1
meesoto x 2 (310mm x 281mm x 45mm)
filter for Sharp
derazor x 2pc
RalliFTO x 1pc
martintylor x 2pc
Thanks!
aCidz
I asked him 2 weeks ago :o His reply was:
Yes, I believe can spec to 45mm for yours. But you go and measure your cavity properly, see if 45mm will have blockage for your prefilter cover. Shd be ok. But check the sides in detail, coz the prefilter has curves that goes in.
If scared block, then spec like 5mm less width to avoid the curve. Think a little about this, you'll get my concept.
Original is just 31mm. Boost to 45mm for TB is good (TB HEPA media is more restrictive), probably end up same airflow (haven't measured in detail).
Alww the seller of the AX40 filter for a customized version. Link to the seller on my site http://acidz.neocities.org/haze/index.html
Cyno505
ralliart_ray x1
john doe 84 x2
defytherules x2
JadziaK x 2
Linusz x 2
Asure7 x 1
Cyno505 x 2
filter for Sharp
derazor x 2pc
RalliFTO x 1pc
martintylor x 2pc
Thanks!
