Air purifier?
kimsim
Suspended
Bro Kimsim
I respectfully disagree with you
Unless you calculate pm2.5 particle readings before and after you wash and prove that it is still able to filter particles, otherwise by visually saying it still works after washing, not convincing
Hope I didn't offend you,
For a true peace of mind, get a new filter when it's time to change
Peace!
Yap you are correctly, actually human are very interesting many thing.
So just do a demo only.
Tryg2015
Yes... Just needed to state clearly because new readers may just come in and see your photos and don't understand you were experimenting, and thought it will work...
Akai Ryu
Check model of ur vacc and hepa...not all vacc hepa can be washed...or just replace every 6 month or a yr....very cheap as compared to ap hepa...
idiots
I dun have air quality measuring equipment so can test only using the sensor....anyway wat's done have been done...can only llst...my dad just use the shower head to spray water, no scrubbing...the fibre destroyed anot, I wouldn't know cos cannot be seen by naked eye also...anyway just use for now until the replacement I MO with kimsim comes lor...
Asakura
so why dont pay 40 for extra original filter which u need to pay 70-80 when buy separately?
noobiee
sorry ah but i really cannot scan through so many pages
i have 1 samsung ax40
however i do not have any extra filters. can recommend any local shop got sell filter for this model?
is it die die must buy from taobao or qoo10 seller daiso himself?
spidey19
Is there a problem with my AX40 sensor? The cleaniness indicator only shows white colour, I tried moving it around the house it doesn't change colour.
