Air purifier?
kimsim
Suspended
Finally all done for my DIY ventilation to prevent dust & haze enter to my bedroom or toilets else
To remain the old school window very useful for ventilation as well.
sacredrays
my ax40 hepa filter got one smell sia.. every time on the ap will have strong smell, but after a while used to it (or not much smell). used it for like 1-2 weeks only, cannot try sunning it cause no strong sunlight throughout the day because of haze.. :s13::s13:
kcwlee
Bro WRX,
Need your input on this, I remember last year u were using Amazon Fellowes filters for your AX40.
With the rising price of TB filter and shipping cost, would it make more sense to buy the filter from Amazon instead as you get H13 grade for just a few dollars more. But of course Amazon ones are not plug and play still nd to DIY.
Thanks!
WussRedXLi
Just in, Shunfeng delivered at 9AM+ and went into warehouse and into 4PX system 4 mins ago
8.9kg.
Not going to consolidate, direct pump over.
Anyway, i think initially when it launched, it was RMB 899. Maybe next time when it's not so hot, it'd go back to RMB899
linusz
Useful to remove smell and improve ventilation? Window panes still closed
gravavva
Got use when the air seep in from the louvres? I think I would tape those louvre not surrounded by the filter.
xyz2006
Is the 3M aircon filter still can be use as I found at my store room I purchased 2 years ago. Tks.
kimsim
Suspended
Not really necessary you need to tape it as 100% suction out, but at least 90% helpful from the dust and air ventilation out.
kimsim
Suspended
8.9kg.
Wow can't wait for review after got it
derazor
8.9kg.
This one like Xiaomi Type ( cylindrical )
Didn't consider Baomi? Design so nice~ ;)
gravavva
:s11: If you are pulling clean air in from the house to the outside doesn't that mean you won't need the filter anymore.
Akai Ryu
Pull air out with ventilator why need filter? Pull air in then need mah
Edited: k kimsim is drawing air in...then some filter better than none...oso keep louvre window for normal day usage without turning on ventilator.
Personally would prefer pull air out...then shut dwn ventilator on normal days
