Air purifier?
Tryg2015
IMHO sharp A28 is ineffective against the current level of sustained severe haze levels
Just now I tested my sharp a28 in MBR after airing my room. In 10 min it brought down raw reading levels from 180 to 70. Not bad I should say. In 20 min from 180 to 30. (After that ended experiment, didn't check any further as B5 no power already. I suspect it will do down further given time)
And this is using my ultra sensitive B5 which need to divide by more than two to normalize.
Of course I need to say that I upgraded the original filter to a commoner hepa filter from TB.
I do think it's sufficient and value for money, especially since I bought it last year at $99
WussRedXLi
Have been gunning the M8088A since Friday night. Speed 2 326m3/hr and Speed 3 520m3/hr and sometimes Jet mode 580 m3/hr.
No issue with overheating, 32.1 deg C motor temperature, other surfaces in the AP 29.8 deg C.
No need la, thanks for the offer. My current set up of 3 APs enough to tide me till next El Niño
My living room quite big. The AX40 is fine usually. But on Friday keep going into red, especially when I need to open kitchen door to go in or not. Guess it has been taxed. Just in case another prolong PSI above 200 period, I need one more for support.
WussRedXLi
168 m3/hr in high and quite noisy. 100-110 m3/hr in medium, still somewhat noisy (noisier than the AX40). Give 15% discount for stock filter. Can tahan in those brand new BTO bedroom of 2.7 x 3.4m lah. (maybe not MBR)
WussRedXLi
Boss, so you will recommend m8088a over AX40 for a bigger area like the living room?
Which seller you bought from? The one with the most number of people purchase from him? There are a few with the same pricing.
Best is still go carousell/gumtree and get the cheapies. :s22:
Living room, both are ok, there isn't a BIG difference in real life.
I remember gunning 1 piece of LG PS-R459 (200m3/hr med speed), 1pc LG PS-S209 (180) and 1pc Midea KJ30FE (probably around 280 m3/hr in Low speed) non-stop during that Hari Raya Period which went into hazardous zone and the most important thing to do is to keep any door/window closed without any gap. That's 660 m3/hr of horsepower.
Even with the louvre window pane for the yard-kitchen closed, my kitchen registered 70 ug/m3 on the B4 while living room was 40-ish.
MIL forgot to close the yard door + no wind at all coz all other interfaces are closed tightly, whole house shot up to 100-ish.
All my normal windows and yard door got rubber sealing, during thunderstorm if closed tightly got no woo-woo sound, leave a very slight gap and you can heart the loud whistle. Confirm tight, only gaps are main door and yard louvre windows pane.
323 vs 439 m3/hr 7 minutes difference 1000 ug/m3 -> 1 ug/m3
laeticia
The local version is AX41 which the RRP is $549...Buy the AX40 is below $300 and get an extra filter...It is a no brainer decision if you ask me...
I enailed Samsung Sg replacement filter for AX41 costs $114. Machiam daylight robbery
laeticia
Last night in my bedroom my AX40 keep changing colour, even when the door is not opened. I suspect my room is leaky...
WussRedXLi
Ok. It's about $330 including shipping. If go by the slow method, shipping a lot cheaper.
I tot it's SGD298 everything in, that them when I got it......
999 unit price. add RMB80 for shunfeng (optional, but recommended).
235 4PX to SIN.
Total 1314. Add 3% TB charge and then 2.5% CC forex = 1387.
SGD 305 now current exchange rate.
It could be SGD285 if you don't need shunfeng go with its free shipping, maybe it's 中通 or 圆通。
My speedpost uncle knows me, coz I get iherb, AMZ as well. He's an ok guy. Your mileage may vary, coz some speedpost folks may be !@%@#$.
4PX - Transrush is extremely gentle. I have not heard of issues.
WussRedXLi
Seen this Philips before last year already. But not available locally via qoo or similar.
Very silent for 690 m3/hr, and power consumption is low.
It's a viable competitor to the AX60. (711 m3/hr, 48W, 48dB).
makav31i
Buy from Goni and HappyMall is $51 or $54.99 respectively using the $10 halloween coupon...Add in q-points, gift card discound and credit card rebates, buying locally is never a good idea...
laeticia
Yup I only emailed out of curiosity. Gonna stock up from Happymall after getting a couple of $10 coupons
Honestly how many do I need? I have 1 spare per machine currently, thinking of getting 1 more per machine. AP all bought this Sept/Oct
MIVEC525
I got 5 for my AX40.....:s13:
Akai Ryu
Double filter replacement price...like the castor wheels too.
Think developed for cn market only?
cnotsniw
I want ... but 9999 RMB ??? too expensive liao. :(
wonder how much the retail price of the AX60 is in korea iteself? (not sale price in Qoo or such).
Anyone going to Korea for holidays can go check it out?
