NWT1978
- Dec 1, 2001
wow...lucky we have got it yet...hopefully it keep on blowing in the same direction and not towards us...
Haze Forces Closure Of 15 Schools In Perak's Manjung District
IPOH, July 22 (Bernama) -- The Manjung coastal district in Perak was enveloped in haze at a 'very unhealthy' level at 1 pm today, forcing the cancellation of the afternoon session of 15 schools there.
The six primary and nine secondary schools, with an enrolment of 5,945, were ordered to close their afternoon sessions after the Air Pollutant Index (API) rose to 247, said Perak education director Mohd Idris Ramli.
Tomorrow's morning session at the schools would be cancelled if the API remained above 200, he told Bernama.
Mohd Idris named the primary schools as Sekolah Kebangsaan (SK) Seri Manjung, SK Kampung Dato Seri Kamarudin, SK Methodist (ACS), SK Methodist, SK Convent and SK Simpang Empat.
The secondary schools were Sekolah Menengah Kebangsaan (SMK) Seri Manjung, SMK Ahmad Boestamam, SMK Seri Samudera, SMK Nan Hwa, SMK Methodist, SMK Methodist (ACS), SMK Tok Perdana, SMK Ambrose and SMK Dato Idris, he said.
Mohd Idris said he had instructed the district education officer to close the afternoon sessions of the schools until further notice.
The portal of the Ministry of Natural Resources and Environment reported 'unhealthy' levels of the haze in Kampung Air Putih, Taiping (117), Jalan Pegoh, Ipoh (114) and Tanjung Malim (115).
An API reading of between zero and 50 indicates good air quality; between 51 and 100, moderate; between 101 and 200, unhealthy; between 201 and 300, very unhealthy and over 301, hazardous.
-- BERNAMA
> 200 they close liao.
For us, 4 days above 200 also biz as usual.
So nice.![]()
You guys may wanna pay some attention to CADR: Clean Air Delivery Rate.
Clean Air Delivery Rate - Wikipedia, the free encyclopedia
and check out the test done by Association of Home Appliance Manufacturers (AHAM)
About This Program
Hi all, just wish to borrow this thread to ask for advice on air coolers cos alot of experts in here.
i had an EuropAce air cooler used for a few yrs liao, last week suddenly spoiled. its those type where u put iced water or ice cubes below, then the wind will be quite cooling.
quite useful for my living room last few weeks, in this terrible weather.
now suddenly spoiled, so i intend to buy a new one but cant find similar one from EuropAce,
for price n functions, im looking at this
ifan IF7860
selling for $189 at Qoo10,
you all think can buy anot huh?
it gives longer warranty compared to other brands.
Thankssss
Thanks alot Chuanz!!Dunno this brand/model good or not, but u can check with GAB price or wait for Rakuten SG 10% or more coupon code (got one seller @ $188). Rakuten SG got new coupon code every day, but dunno they will continue to do this till when.
Fairprice Xtra @ $169 w delivery http://www.whatsupatfairprice.com.sg/wuafp_modules/Specials/pdf/1405525742.53945_1.pdf
yep. cadr is not something that's missed out in here definitely![]()
hope the rest don't make the same mistake.
true but i still see a lot of guys enquiring about air-purifiers with no certified CADR ratings...
and a proper CADR rated air purifier isn't a simple mathematical CFM * particulate removal (although on surface it does seem to suggest that).
It is much more involved. It requires a measurement according to a procedure specified by ANSI/AHAM AC-1. (see quoted text below)
personally, i wasted money on 2 different brands (of which one is v popular) of air-purifier before i appreciate the importance of CADR...hope the rest don't make the same mistake.
"The CADR for each particulate is determined by a separate test sequence in the test chamber. It is necessary to measure both the natural decay (air cleaner turned off) and the measured decay (with air cleaner turned on) separately for smoke, dust and pollen. Prior to the start of the test, the chamber must be thoroughly cleaned. The air cleaner is then set up in the chamber. Air cleaners under test are normally placed in the center of the chamber on a table. A separate test stand is provided for mounting plug-in and wall-mounted air cleaners.
The chamber’s environmental system, the recirculation fan and the ceiling mixing fan are turned on. The background concentration of particles is monitored, and when an acceptable low background concentration level is obtained, the chamber’s environmental control system is turned off. Particles are then injected and monitored to obtain a natural decay.
Next, a measured decay test is conducted. The particulate matter being tested (smoke, dust or pollen) is injected into the room to the required concentration level specified in the standard. The air supply used to inject the particulate matter is then turned off and the injection valve for the pollutant closed. The pollutant is allowed to mix for one minute via the recirculation fan and the ceiling mixing fan. The mixing fan is then turned off and one additional minute is provided for the mixing fan blades to stop. The particle counter sampling and the data acquisition then begin. There are slightly different sequences for the smoke, dust and pollen. The data acquisition is done through a 20 second sampling at one minute intervals. The test for smoke and dust is 20 minutes. For pollen, the test is 10 minutes. The minimum number of acceptable data points must be obtained (at least 9 for dust and smoke, 5 for pollen). Following completion of the test sequence, the data analysis is performed."
I only cut/paste a small fraction, for more information on the test: http://www.aham.org/ht/action/GetDocumentAction/i/13886
229 hotspots at 1556h
Lai liao again....
Little typo. Should be 329 hotspots.
More worrying is the appearance of those hotspots to the south which the prevailing wind can carry to Singapore.
Really lai liao.
Really lai liao.
