Alldocube iPlay 70 mini Ultra/Pro ( 2025 )
xonix
ULTRAPRO
SIZE208 x 129 x 7.9202 x 126 x 7.3
WEIGHT335310
SOC7+ GEN 3MT8791
RAM12 GB8 GB
DISPLAY8.88.4
RESOLUTION2560 x 16001920 x 1200
REFRESH120 HZ90 HZ
SIMNODUAL SIM 4G
WIFIWIFI 7WIFI 6
GPSNOYES
SOUND2 FULL BOX DTS2 BOX
USBOTGOTG
CHARGINGCHARGING
DATADATA
DP OUT
CHARGEPD 20 WPD 18 W
IceCoolBoy
Dont know why they change location of speakers for iplay 70 mini pro. Have been waiting to buy but now just hope other gaming tablet has a 4G version
xonix
alldocube probably just took the older iplay60 mini tablet and refreshed with new chip. Get the ultra instead and use phone wifi hotspot ?
alex22
I go see the pro, not in stock on ali, link from their brand page. I think taxation flip their table
xonix
If desperate, can order from Amazon Japan, ¥24,649. But do note, the speakers for the Pro is only one side ( near USB c port )
RaebRalop
Hi Guys
any idea what’s the difference between IPlay Mini Ultra and the one that’s name as mini 3 ultra from 拼多多?
I see both spec exactly the same -__-
xonix
Hi Guys
That's what it's called in China
alex22
so it's technically the same i assume...and those in alipayexpress is just cn rom with google play store installed by the vendors ?
Some aosp rom will show ROW (rest of world).
Cn rom usually dun show row
Parka
My text review is up
https://www.parkablogs.com/content/alldocube-iplay-70-mini-ultra-review
In short, really good tablet. Huge upgrade over the iPlay 60 mini Turbo. Whether to spend the USD 100 more to get the better tablet comes down to how much you want to spend. But if you spend, I'm sure you will be very satisfied with the user experience.
The tablet looks good, feels good, sounds good enough, is fast.
Downsides
- No biometric unlock
- No cellular option
- No grid view for task switcher
- Don't expect OS updates
Dorkable
I find it so weird that the mid-tier iPlay 70 Mini Pro runs Android 15 while the premium iPlay 70 Mini Ultra only has Android 14 😔 And we know Alldocube never ever provides any Android version upgrade.
Parka
The tablet is installed probably with whatever Android version it is at the time of manufacture.
alex22
Yup, usually is like that one.
They dun even provide any security update for all the alldocube units that i bought so far.
OTOH teclast does provide. My android 10 and 11 units still get
xonix
In case anybody thinking of buying from taobao, the official store confirmed their unit will not have playstore preinstalled. Wait for global release version if you don't want the hassle
