Alldocube iPlay 70 mini Ultra/Pro ( 2025 )
xonix
There was a mini sale on Aliexpress last week, pulled the trigger on iplay70 mini ultra
Teo Ming Ern
Such a shame the Ultra has not cellular
It's the chipset I guess... probably more expensive with cellular... they've to cut some corners to get the price down... even now the Pro is pretty expensive...
Teo Ming Ern
My text review is up
https://www.parkablogs.com/content/alldocube-iplay-70-mini-ultra-review
In short, really good tablet. Huge upgrade over the iPlay 60 mini Turbo. Whether to spend the USD 100 more to get the better tablet comes down to how much you want to spend. But if you spend, I'm sure you will be very satisfied with the user experience.
The tablet looks good, feels good, sounds good enough, is fast.
Downsides
- No biometric unlock
- No cellular option
- No grid view for task switcher
- Don't expect OS updates
Thanks for the reviews bro! They're good... much more comprehensive than the well known international writers or YouTube channels...
Dorkable
Alldocube launching their Ultra Pad on AliExpress come 10 Sep 2025. It is basically a bigger iPlay 70 Mini Ultra.
- Android 15
- same Snapdragon 7+ Gen 3 SoC
- 12Gb ram 256Gb storage with Microsd Card support
- 13" 2.8k 144Hz IPS display 700nits
- 15,000 mAh battery with 33w fast charging
- USB 3.1 Gen 2 Type-C port
- Wifi only Global version
Parka
I've the Alldocube UIltra Pad in hand already.
The hardware is really good except with these downsides:
1. No face or fingerprint unlock
2. Audio doesn't have much bass but at least does not sound hollow. Sounds better the iPlay 70 mini Ultra
3. UI scaling option is limited so many apps/webpages look like zoomed in handphone UI. Such a shame because the high resolution is capable of showing more
4. Don't expect future Android OS updates
For USD 299 not including shipping cost, the price seems alright.
Performance is good, fast. Display is bright, vibrant and sharp. Battery life is 2-days since it's a 15000 mAh battery.
ALLDOCUBE iPlay 70 Mini Pro Tablet 8.4" MediaTek Dimensity MT8791 Tablet Android 15 90Hz High Refresh Rate 1920x1200 Resolution 16GB+256GB+1TB Expansion 6050mAh PD18W Dual Speaker 6-Axis Gyro WiFi 6
https://amzn.asia/d/dO0umyJ
Unavailable
8GB/256GB version available from Taobao official Alldocube Tmall Flagship Store 酷比魔方数码旗舰店
They have both China version from RMB 1088 and International version (Google Play version, iPlay70 Mini Pro) from RMB 1118.
【淘宝】假一赔四 https://e.tb.cn/h.S4vCKwF55k8es0t?tk=1nny4CKTJ8s CZ225 「2025三代酷比魔方掌玩mini 3 掌上通话迷你90Hz高刷平板电脑8.4英寸4G全网通安卓15游戏学习iPlay70mini Pro」
点击链接直接打开 或者 淘宝搜索直接打开
Looking for a cheap but reliable 8 inch tablet as well for Chinese Entertainment apps, no need Google Play, around S$200 to S$250.
I like my previous China version Huawei M5 Lite (M5 青春版) 8 inch tablet bought in 2019, Kirin 710 CPU, 4GB/64GB version with 1920*1080 LCD display. It is now running Harmony OS 2.0 but unfortunately it becomes quite slow, probably due to the 4GB RAM.
Recently I bought a new Huawei Matepad SE 11 Lite tablet 2024 version, 8GB/128GB version, at RMB 1019. Interestingly (or unfortunately) it is still using the Kirin 710 CPU after so many years. And it runs Harmony OS 3.0 (the non Lite version runs Harmony OS 4.0). Thanks to the 8GB RAM it runs rather smoothly. But I feel 11 inch is just too big for my use case.
xonix
If you need OS updates, then alldocube is not for you. They do have "decent/acceptable" hardware at the $200-$250 mark. FYI, the iplay 70 mini pro has only 1 single speaker.
I bought the iplay 70 mini ultra version instead
Thanks for the info.
I will try to get used to the Huawei Matepad 11 SE Lite version first. It has pretty low HW spec and unlikely to have new Harmony OS updates either. But it does have four speakers.
We have working iPad 2018 and iPad 2019 now. They were used by the kids previously but under used right now. They are not very good for my use cases though as the Chinese Entertainment apps are not available in the Apple App Store (mostly not available from Google Play Store either).
PholkLorr
Taobao selling the iplay mini 3 ultra with Google (same as mini 70 ultra) for 328$sgd (listed price 1566rmb) all in worth to get? I see aliexpress is abit more expensive if factor in the gst.
