AMD Mobo need K CPU to overclock?!
ikkozilla
All B350 and X370 boards can overclock via multiplier
1300X can overclock quite a fair bit, but be careful. The Wraith Stealth cooler it comes with is nowhere near as imbar and overengineered as its larger Wraith Spire sibling
Wraith spire imba ah? Then wraith max? Jin satki?
Sent from Xiaomi MI 5S using GAGT
royfrosty
guessing he using tkl or smaller keyboard...?
Yes, + and - I am aware. But TS was saying he needed to press Shift & +/- is quite strange. Pressing Shift is redundant I believe. At least I did not press Shift when changing any values on the same motherboard.
Some older MSI boards also does the same thing, need to hold shift in order to just dial up the multiplier.
Till during Skylake era that is where user can input the multiplier number. But iirc the shift+ + is a must if you dont input directly lol. Now that i see TS using Giga, then only i know that Giga follow the same thing.
Typhoon PC
One cannot doubt that the Wraith Spire is one of the reasons the Ryzen 5 1600 (which comes with it) is such a best seller, giving it the overclocking headroom it has stock and right out of the box (up to 3.7Ghz)
Max we have not had the chance to try it out as of yet
