Android TV Box
gregory_choo
Dear Gregory sir, can you please kindly recommend afew good china apps? Thank you :)
google for "今日影视TV版APP"
and/or
search for newfast.tv in playstore.
The 2 above are suitable for installation on TV box.
You can also install 影视剧场 on your handphone from handphone's playstore. 影视剧场 has a DLNA casting function, if your TV box has 酷喵影视 installed, the video can be casted to 酷喵影视. After casting, you can turn off the handphone without affecting the video on TV.
Candydream
Can anyone recommend me to buy which box that is sort of like tanix-tx5 max?
i intend to put in the room but i'm worried that the wifi connection will be poor cos my router is in living room and there's a 5cm thick partition in between the living room and my room. my needs: able to watch hk, china dramas, movie & us movies.
Thanks for advice.
vickyboi
Yes.... I got one at home for nearly 6 months works like rock
Ok great to know. Especially from someone who has used it here.
How much you got it for bro?
I'm intending to I stall Kodi and transfer all my downloaded stuff into it.
Can VPN and ftp be installed on it?
Also for IPTV do you subscribe to any? I'm more for sports. Or do you get free play lists of the internet?
Sorry for the bunch of questions!
Sent from OnePlus ONEPLUS A6010 using GAGT
vickyboi
Anyone have feedback or review on Beelink GT King?
mankind66
What are the rotation or orientation apps that will work for Android tv?
So far, i am unable to find a workable app to force rotation on apps like apkpure on my Android tv. It remains in portrait mode.
Thanks
gregory_choo
Thanks
install and run 'set orientation' once
kombat75
So far so good.
I just renew my MYIPTV from Carousell and it look legit.
Cheap and reliable.
Now MyIPTV is more stable compare to others i have try.
cybertech
MYIPTV in Carousell more expensive than Shopee, with Bank of the day Shopee credit card promotions, -$10 even cheaper :D
tamps guy
Hi all, which android TV box best n reliable n gd value now?
Wow, n since many TV tech local experts here, hi all 你好,now old philips TV 49pfa4300/98 failed me just after 3 yrs warranty expired , called TV Repairs, they said nowadays tvs have built in fail dates, wowt last 5 yrs unlike the older ones, true!?!? fainted, I thinking of getting an affordable best hse hdb room TV replacement at best prices n features haha, Singaporean guy way lolxx
Thinking of getting this philips 6000 series 4k ultra HD led smart TV , 50put6103/98, Philips say launched this Yr only march, at 650 (best price I can find le, includes gst, delivery n fixing all ins ) , anyone has use n experience of this philips model, any gd reviews n help much appreciated, thks, :) 😇 😍 😜 😋 😇
Conversely, what abt LG ultra HD 4k smart TV LG 49 uj632t? Or other other gd deal tvs 49 n 50''inch to intro? My budget 600-800 only, thks
mankind66
I saw audio house sales at expo this weekend, can try.
mankind66
BiggieZee
I got shield tv currently but looking to sell it to get tv box with both usb 2.0 n 3.0. Best move or shud just buy external usb hub with 2.0 n 3.0 inputs? Shield kind of lacks customization which im into. Even though i manage to use custom home launcher
gregory_choo
why need both 2.0 and 3.0? 3.0 is backward compatible.
shield tv is the best tv box, why change?
it is easy to customize, if you don't know how to do it, you can customize any other box.
block306
I used to have one of those setup box for scv but now unable to receive scv anymore- seems to be due to it going IPTV way. I am looking for some IPTV apps that closely replicate scv's offerings, mainly channels such as axn, fox, hbo, Chinese movies (Celestial, star) and so on. Heard that sunshine IPTV is quite close. Anyone can recommend which ones to look at? Thanks
