Shion
Senior Mentor
- Oct 24, 2008
Thank you
1GB RAM and 8GB storage, should be sufficient ?
Thank you
yes, as long as you don't installed those memory hoggers.![]()
What will be the 2nd best option other than Mi TV Stick ?
Thanks![]()
mibox s
double the price.
if you don't mind paying, actually it is the best option.
ok thanks i think mine 50 or 55.
I will not recommend Mi TV Stick myself even for 1080p. Mi Box S is cheap enough and 2GB memory will make your life better. I use Mi Box S with 1080p.
Or you may want to pay a bit more and get Google Chromecast 2020 with Google TV.
Wow the way u lay it out. I do have a older mi box but it’s running on xiaomi software and I have been reading around on how to install google play store or root it but I can’t find much info. If anyone has info on how to install or root please share. Coz I don’t want buy one more product then it’s not goggle
BTW, what is the model of your old Mi Box China version?
There is no point to root the box and install Google services with these older China version of Mi Box.
If it is not too old and have 2GB RAM, then it can still be used effectively with the right apps.
Even if it has only 1GB RAM, you can try to disable the built-in apps and install right apps to make full use of it.
I go home take photo of the back and show here coz I just want to play YouTube vid and Netflix and Disney plus on my tv that us all
don't waste your time.
spend $70 to buy a mibox s.
or $33 to buy mi tv stick.
you are willing to pay subscriptions for netflix and disney+, that work out to be at least $264 per year. Why try to save a few dollars?
$70 for Mi Box S.
Got lobang ?
For those who want to subscribe to TVB Anywhere+ Premium.
Mi Box S is listed in TVB Anywhere+ support list of Android TV OS devices but not Chromecast 2020.
https://staticweb.tvbanywhere.com/certified-android-TV-list.pdf
You can also purchase the Official TVB Android TV Box at S$121.50 from Shopee to be sure of support.
https://www.tvbanywhere.com/a15_promotion.html
https://shopee.sg/tvbaw.sg?categoryId=2414&itemId=5658162304
The good thing is the official support of TVB Anywhere and built-in Ethernet. But Mi Box S is much cheaper.
[Package List]:
A15 Android TV Box x 1
Google Search Remote x 1
Adaptor x 1
HDMI Cable x 1
[Product Specification]:
OS Syetem: Android 9.0 (Pie)
CPU: Amlogic Cortex S905X A53 1.5GHz;
GPU: GPU ARM Mali-450;
RAM: DDR3 2GB;
Storage: 8GB;
Ethernet: 1* 10/100Mbps (RJ45);
Wi-Fi: 802.11ac/a/b/g/n Dual Band Wi-Fi (2.4GHz/5.0GHz) 2*2;
Bluetooth: 4.0;
HDMI: 2.0;
Maximum Video Resolution: 4Kp60 (3840x2160);
you have to wait for special offer if you want to get it for $70
now the cheapest is $79
https://shopee.sg/-1-Year-Local-Off...Streaming-Media-Player-i.351321948.4471876534
but the better deal is dynalink box at $55
https://shopee.sg/Dynalink-Android-TV-Box-i.13630799.4566113778
it is similar to mibox s, but using a newer and faster chipset.
Can Dynalink box support TVB Anywhere+ ? Thanks
