Android TV Box
magixz
I used Android TV OS on smart Android TV. I prefer the normal type of Android, no need sideload apps. No need Netflix and amazon prime 4k. I have spare S905x3 box at home. So dun need this.
nusntusmu
Hi, how do I subscribe to youku vip in Singapore since we don't have alipay or wechat pay? Youku VIP can access drama without VPN right?
And how do I find and install 酷喵影视 youku tv app into Mibox S?
I believe it is tough now unless you find someone with Alipay or Wechat pay to pay for you. Or maybe there are websites which offer such services. I do not know.
Once you pay for the VIP, then you can watch many shows without China VPN (like Transocks or AJS or things like that). But some shows will still be blocked and will still require VPN. This is the same as Tencent Video.
As for the app, you should be able to download the apk here.
https://pd.youku.com/CIBN
nusntusmu
Thanks. So the easiest way is to watch cdrama on iQiYi? iQiYi app can be found directly in playstore and VIP can be paid via credit card right?
gregory_choo
some shows are blocked outside china even for subscribers. if you want to watch them , without using vpn, use other apps , such as, iyingshi or mudvod. these are free apps catered for overseas chinese. google for official site and download the tv version apps.
Philippng
Hi if i have a google tv and now buying a tv box should i skip the KM2 and buy other versions of Mecool box? perharps the Mecool KIII pro?
Hi Bros
if you have a google tv why is there a need to buy another box. Google TV have what a iptv box have
Zetrio2006
Hi Bros
Think the TV becomes too slow if you install too many apps. Bloated.
If you want to watch TV fast, you have to get tv that loads within 2 seconds.
Philippng
So it's better to buy a seperate TV box?
Today Smart TV can even be faster than tv box. Esp. when u got a low end box.
eg. a sony smart tv load faster than my ubox.
The only different is Ubox come with the iptv and the VOD where the Smart TV is bare.
However, if you are able to setup your own iptv and load your own vod app you will be surprise that the smart tv is a better choice.
Power up and wait for it to get loaded and u are ready to go.
No need extra electricity, save the extra box money, no extra cable and another device to take care.
The future will be smart TV, however as of now Smart Android or Google TV dont have that many app to support
you will need some technical ability to get it setup
standing
Now still got sell ubox anot ar?
Jurchen King
If TS requires Netflix and Prime Video playback at 4K/Full HD, then:
Officially certified by Netflix and Prime Video to support Widevine L1 and comes with built-in Chromecast for less than half the price of Nvidia TV Shield. Also has 2 USB ports to playback locally stored media on flash drives/hard disks.
Philippng
how much this piece cost
Jurchen King
~S$90+ to S$110, depending on retailer. For peace of mind to obtain genuine product, can buy online direct from manufacturer instead of third party China sites. But look out for discount code where available on MeCool website to knock off another few percent.
