- Sep 16, 2018
Hello gurus,
Any problem watching the infinity tv apps from sky media hub box?
Seems to be a box to avoid.
https://forums.hardwarezone.com.sg/...les-13/sky-media-hub-android-box-5457475.html
Hello gurus,
any 64G 4G ram recommend?
Xiaomi TV box good or not?
What are the pro and cons?
I feel like getting one on 11.11 sales.
Can I use my Samsung android phones to mirror the tv box?
Just for reference there are quite some apps for iOS as well from the official App Store for Chinese entertainment and more. You can search Apple App Store for the following.
电视家,idrama,华文电视,欧华生活。
Guys. I need a Android TV box for CCTV channels from China. I don't need anything else.
Any cheap TV box to recommend? Below 50 will be the best
if you need to run only 1 app for CCTV channels (and many other china satellite channels), buy the vscishion v88 at $30 or less.
Post your review here after you play with it.
BTW, you may spend time browsing through the Facebook group. It really has a lot of good info and tips.
cooler than my Minix G4.
My TX3 Max lai liao.
Sian, now dunno should I get a Airmouse.![]()
As for air mouse, I myself do not like them — I am using a Logitech USB Keyboard/Mouse combo myself (single receiver) with the help of default remote in case the mouse/keyboard do not work.
Thanks for the review. It is bigger than my X96 Mini so the heat problem should be less and it should have better design than mine.
Low end Box only has 2.4GHz band WiFi and 100M Ethernet. If you can, use Ethernet for better stability.
You can go to Tanix website and Facebook page to get software update.
Does MX3 come with gyroscope and accelerometer? Thinking of getting 1 for navigation and play simple games with my toddler gal.![]()
Yes that is one possibility from what I read. But the problem is that it is only 1GB/8GB and I do not like the RK3229 CPU. It will be okay for the specific needs but he will soon regret.
I have a generic R69 RK3229 Box with 2GB/16GB (S$30 from Taobao) and my generic S905W 2GB/16GB X96 Mini (S$40 from Taobao) are much much better than it.
No please do not get R69, that is a lousy box. Get S905W based box like Tanix TX3 Max or TX3 Mini.Hi thanks . Probably I will get same device as yours from taobao. R69
