ahboon83
- Oct 8, 2007
Do we get to keep the mesh devices at the end of the 2 yr contract?
Sent from Asus ASUS_Z00AD using GAGT
It will be obsolete in 2 years time like any hardware right?
Yeah I guess so but does not stop me from continue using it
Haha some pple still using Asus wireless N routers
well .. can buy off the shelf at $238 or pay monthly for 2 years.It will be obsolete in 2 years time like any hardware right?
Is wifi mesh better than others home plug?
Can you still connect to your original router wifi or to the first unit wifi?
So any update on the wifi mesh things? Anyone use it/try it yet ? My router will be in my living room, my desktop in my master room which is quite a distance away from the router.
Heard from Singtel they have change the Aztech router. Anyone know which model they change to ? understand the previous router sucks.
in this thread alone, i have spoken on so many examples of how singtel wifi mesh has improved the wifi performance and how it works, maybe you can view the previous posts?
singtel has abandoned aztech-OEM routers for the new singtel wifi gogabit router ac1900...
wats the maximum speed & average wifi speed of the wifi mesh? someone mentioned 800mbps. is that a typo?
max speed as in your fiber speed ? if not wrong for wifi , the max can hit is 240mbps depending on which fiber plan you in. correct me if iam wrong.![]()
that depends on where u placing your 1st wifi mesh unit connected to LAN of your router.
if you place it too near to the router, it will cause interference and i suggest you turn the router wifi off.
if lets say u r placing the first wifi mesh away from the router, like different areas, then your wifi on router can be turned on.
so the devices will be steered between the 2 wifi mesh nodes rather than including your router, so u gotta plan carefully.
Actually its depends more on the client device(laptop,mobile or tablet). If your device equipped with a better and more antenna den u have better speed as well.
But the wifi mesh must connect to the router, how to place it away from router? Hence, I guess most of the user will just place it side by side instead of getting a super long lan cable and place it elsewhere.![]()
