Apple AirPods (3rd generation)
anthonygreenisreal
Hi all, I went orchard store to try out the new AirPods, not sure why it just doesn't fit, it keep dropping out. Is there anything wrong? I end up buying the gen 2 with wireless charging, as I prefer the longer "stick".
Nothing wrong. its just the ergonomic of your ears and the airpods 3 no fit.
ForumRider
ok cause I used AirPods gen 1, 2, AirPods Pro and all have no issue with the fit. Just this gen 3 does not fit my ears at all... quite disappointed that I can't use it
anthonygreenisreal
yeah if you are using the airpods pro at least you can change the ear tips to different sizes or even 3rd party ones. Likely you would be able to find a suitable fit.
ForumRider
I just realised the right side of the airpod tend to have issues, my right airpod and airpod pro both died after 1 year plus of usage.... seems like getting apple care for airpod is needed.
ericwilis
Shopee flash sale is on. AirPods 3 at $228
Still have it? Can’t seems to find it
So far I found cheapest is Qoo10 239 sgd. seems export set as it is shipped from korea
szeli
So far I found cheapest is Qoo10 239 sgd. seems export sell as it is shipped from korea
e flash sale was only for 1 hour iirc. $239 still a good price
szeli
shopee flash sale is on again. $239. about 15mins left
TA200
It seems like not many interested in this. I am interested as I might not be suitable for TWS with silicon tips. Will caused itch in my ears. Interestingly, it's available for collection in all 3 stores! The thing holding me back is whether does it fit well or not.
guess it's not made to fit all
browse on carousell, quite a few sell due to 'not fit well'
best to test it before buying
mrchowking
I actually share the same experience with my airpods because it has been a reoccurring experience throughout my airpods bought along the years
Mclairs83
Amazon Prime members can get airpods 3 at $219. quite a good offer.
pchltws
Just got my Airpods 3 from South Korea via Qoo10 and upon opening out to check, found a hairline scratch on the case, so sad.
TA200
spatial audio - is this something new from Apple or all this while is around?​
