Apple announces new 14 and 16-inch MacBook Pro, powered by new M1 Pro and M1 Max chips
*adiBOY
What is the MagSafe port for? I hope it comes with a usbc cable for charging. I share the usbc charger with lots of stuff…. Weird to use a seperate cable for one device charging ….
MacBook Pro comes with USB C to MagSafe cable. You can still charge via USB C.
TrueBeliever_jh
The notch is so unnecessary.
The direction that Apple is taking is interesting.
They extended the screen upwards to surround the camera housing and use that as the menu. So effectively, minus the menu, you are still getting back that 16:10.
Is the notch ugly~? Of course. But I must admit the center portion of the menu is of little uses. Unless the app got so many menu options.
szeli
Boiijek
Pretty weird how it is getting backordered in other countries yet the sale hasn't even started here, especially without an ETA too
TrueBeliever_jh
Probably not enough to fulfil everywhere loh~
Our market probably not their priority.
szeli
I believe  SG will have stocks for here. just wait a couple of days for orders to open. iirc it’s been like this every time dunno why some r so flustered
Parka
Not sure if that notch is classified as technology.
I fail to see how that notch is going to save time/money or make people more productive.
It's perfectly fine to leave that space alone.
Other companies have already shown that it's possible to create laptops with thin bezels.
But this is Apple. If you want to use MacOS, just take whatever they give.
Even Android phones that copied the notch have ditched the notch a long time ago.
*adiBOY
The notch is there for user to get accustomed to when Face ID is implemented within the next couple of years. Apple doesn’t put stuff or features in for nothing especially aesthetically wise.
TrueBeliever_jh
Oh certainly not, it's jus a 1080p front camera. Remember current FaceID cannot be housed into such a thin screen.
Staying connected is more important than ever. That’s why the new MacBook Pro camera has double the resolution — 1080p — and uses a lens with a wider aperture that lets in more light. Together with a larger image sensor that has more efficient pixels, the camera delivers two times better low‑light performance.
As for Android that were copying Apple, they jus wanna make things smaller than what Apple has, so called out innovate, so they kept having smaller notch, punch holes, popup camera, and even under the display.
bolts
Suspect it will become backordered till January as soon as it’s available for ordering.
wind30
But I prob won’t use it to save on extra cable. The usb c cable needs to support high power delivery if one is thinking of charging thru usbc.
I have the 2019 16inch. I personally like the usbc charging and touch bar… the most irritating thing is the heat generated… the thing is crazy hot when gpu get used.
Glariel
if u like the touch bar like me and @Snoweagle M1 Macbook Pro is the way to go 🤭 🤭 🤭
arvinsim
Ehh, it's probably fine for those who want base models. But for someone like me who wants to BTO, it make take much longer :(
arvinsim
Which makes me believe that to get the best bang for buck, better get a "good enough" machine and replace as you go rather than go for the top-specs but get stuck with it for a longer time.
