Asus 290 r9 Ref
Quest
Lol, simi expert.. Only burn it once nia...
That cost like US$100+ or S$200+? Might as well spend $100 more for non ref cooler? Summore gt warranty. U use the artc cooler, bo warranty on both sides.
artc cooler III cheaper.....can order from taobao :o:vijayadmin:
Yureak
ya, i saw a youtube on attach G10 on a 290, the vrms is only cooled by a fan :eek::vijayadmin:
what if u attach some heat sinks? i bought some off ebay to cool some surface parts not covered by my full cover waterblock
cyberwave
full cover waterblock nvr cover certain parts? like that not called full cover alr ma :s11:
royfrosty
It doesnt mount properly. You require to glue onto it. And you need a large heatsink to cool it down.
Vrms are rated at 105deg. Technically speaking you will need a good heatsink output of 300w thermal design to cool it off.
Only 1 gpu has a unique heatsink and is in favor of the g10. And that is PCS+ cooler from powercolor.
They have 2 seperated heatsink. One for core, one for vrms.
Yureak
Nowadays you can search EK blocks, full cover means vrm, memory and core nia.
There are other surface components which get slightly toasty too especially when we do extreme oc
Yureak
These heatsinks come with thermal adhesive tape to hold it together. Well better than no heat sink if ts wants to try
shadow84
Thermal adhesive tape also problem.. if too strong, will rip off ur VRM if u try to remove. Dun forget, they are all surface mounted, quite brittle. Second, the adhesive tap has weak thermal conductivity and will nt be effective in shifting the heat out of the VRm and into the heatsink.
