Is there any region lock if we get ASUS router from China?
Since this is local set you should be able to get a new replacement set since it should be within 3 years warranty period.
You may want to contact MyRepublic first and then see if you need to get replacement from MR or Asus Singapore.
Just go straight and walk in to Avertek, ASUS, since MR is not the one providing after-sales support.Think my ax 11000 pro just died. MyRepublic set. No wifi and lan connection, did hard reset also.
Yeah I did this. I realised there are some problems with certain units not being able to be used as Aimesh nodes.Just go straight and walk in to Avertek, ASUS, since MR is not the one providing after-sales support.
Probaby only require the invoice or deployment date of the router by MR for verification IIRC.
This is indeed an affordable option compared to the GT-BE98. Sadly, it lacks the 6Ghz band.ASUS’ new RT-BE88U router is a more affordable way to get your home ready for Wi-Fi 7
To enable users to maximise its wireless performance, the RT-BE88U router has a 10G SPF+ port, a single 10G WAN/LAN port, a 2.5G WAN/LAN port, and three 2.5G LAN ports, and four Gigabit Ethernet ports. It also has a USB 3.0 Type-A port that can be used with a portable 4G/5G router as a backup. This selection of ports makes the RT-BE88U suitable for users who have subscribed to 2.5Gbps and 10Gbps fibre plans.
The ASUS RT-BE88U is available now and costs S$629. You can find it on Lazada, Shopee, and the ASUS Online Store.
May I ask the safari speed test was on what device and which wifi frequency ? 2.4 or 5.0 ghz ?Hi xiaofan, thanks for your recommendation. I bought Asus TUF AX6000 for my StarHub 5Gpbs.
I tested on safari speed test for my new Asus router.
The result is 119.3 (download) & 87.6 (upload).
May I know if it is normal?
Because I tested the bundled Nokia router . The result is 555.4 ( download) & 10.3 ( upload) .
Hi, I tested on 5.0 ghzMay I ask the safari speed test was on what device and which wifi frequency ? 2.4 or 5.0 ghz ?![]()
Go to web gui, wifi settings and fixed bandwidth to 80mhz or 160mhz, you should see the speed increase. Provided you choose a good test server in speed testHi, I tested on 5.0 ghz
I just gotten tuf ax6000 China. Do I need to configure to local firmware?
Hi Xiaofan. Which is the longest range Asus route u would recommend. It is for a 4br condo unit that my tenants are complaining of weak signal. Current set up is Asus ac68uNo need, same firmware.
I 100% agree, placement is the key. Using 1 XD6 also can cover 100% my 5 room hdb flat with the weakest point hovering 3-4 bars (out of 5 bars) with speed test easily 300mbps+You have to post the floor plan (with details of the LAN ports in the rooms and location of the FTP and ONT ) to see if single router can cover the full flat or not if that is your intention. Placement is key.
What is the internet plan used? Using ONR or ONT will also have impact on the network configuration.
I do not see why not. you can set the router to get dhcp IP address, then disable dhcp server function or ap function (assuming DHCP is from main router and you do not need any wifi) then the old router will function like a switch.Is there a way to make old routers act as switch? I have an ax88u which i dont want to make an access point coz for some reason if i mesh or access point and disable the radio, seems like the rest of the radios in primary and other nodes are impacted. Nonetheless why question is can old routers be configured to act as managed/unmanaged switch?
