Asus GTX 970 display problem
dunnoX
Hi,
Does anyone know why my Asus gtx 970 is displaying correctly (fuzzy lines across the screen)? Card is brand new.
This is what I know so far:
- Both monitors work fine together with onboard mobo display
- U2713HM works fine @ 1920x1080 res
- Fuzzy lines appear when res changed to 2560x1440
- updated to latest drivers
Set up is as follows:
Asus GTX 970
Dell U2713HM (connected with DVI)
Samsung (connected with HDMI)
dunnoX
Update:
coloured lines appear on screen from boot (mobo splash screen) all the way to windows login
mnemo_05
make sure you are using a dual-link dvi cable.. i had the same issue with my u2913wm when I accidentally used a single link dvi.. hope this helps.. you may also consider trying a HDMI cable..
dunnoX
ok just checked and was actually using single link dvi cable. I think that's the problem. Will try out with a dual link dvi cable asap. Any shops to recommend for getting one?
Goodshot
Simlim or any ahtiong shop should sell le
pa9797
Does your monitor has DP port? I prefer to use DP as it is easier to handle
mnemo_05
any decent hdmi 1.4 cable will do.. do not fall for those fancy expensive ones.. tests shows that they do not offer any advantages over the other.. sim lim got 1.5m for 6sgd I think.. or cash converter if there is one near you :)
yukita
dell 2713 series normally comes with DP cable... do u have it? maybe can use that one instead
