Just finished setting up my BE96U purchased from USA.
With 320mhz bandwidth used for 6ghz band, I was able to get 1452mbps download & 1201mbps upload with 1 wall between router and PC client (MSI herald BE). This is about 50-80% improvement from 6ghz speed from BE92U.
The BE96U has access to the upper spectrum of 6ghz band which is not approved by IMDA. To comply, I've manually set the control channel to 85 (lower spectrum). My BE92U now running as Access Point is using control channel 5 to avoid channel conflict.
BE96U
BE92U
