Auto rebooting issue
nexusRAGER
update guys.
It was indeed the psu.
Guess it spoiled during the period when i was testing the other parts.
Gonna go down and buy Seasonic tomorrow as i find it troublesome to rma with TD
Again, would recommend nigel if you need help, he lent me his psu to test!
jtjt00
i'm currently considering Seasonic X series 650w,
the price difference between that and the Prime Platinum is not too much though hmm
Go for prime platinum, longer warranty & higher efficiency. Price between platinum & titanium is much bigger at $60, kinda hard to justify 2% more efficiency!
You can also consider egva p2 platinum at $219.
leo0o0
good that you managed to resolve the issue :)
update guys.
nexusRAGER
no more platinum :(
went for the gold instead
nexusRAGER
ok so i have another issue :s22:
my cmos auto resets when i boot up the computer.
When i boot it up it will reboot and cmos resetted but pc does not crash or reboot when i am using.
Is my CMOS battery the issue?
leo0o0
try resitting the cmos battery and ensure the cmos jumpers are in the correct position?
archyng
had the same problem. change from one powerpoint to another powerpoint on the same socket. problem solved i suspect the other powerpoint might have some issue but im still using it to power up a multiplug powering my monitor and moca adaptor. try plugging it into the power point directly and not thru the multiplug
still wondering if could it be mobo or your hse power issues (there is 1 guy whose hse power is lower than normal would have in current flats)
nexusRAGER
another day another issue.
Cam software detects my cpu fan is not working...
but the temps are ok, just that some time cpu load shoots up high and once or twice 100%.
How do i check if my pumps are working?
ZrE0_Cha0s
rma everything.
sells them when u get back everything.
build nicely and sell to others.
get yourself a new pc XD
done :s13::s8:;)=:p
next even though its family maybe u can try asking to switch with your bro? as in your pc and his pc exchange?
nexusRAGER
rma everything.
done :s13::s8:;)=:p
his pc no issue haha
nexusRAGER
after facing all this issues..
i gonna just buy everything corbell or convergent from now onwards easier rma :(
