Aztech DSL7002GRV-(s)
hellslayer
Hi guys,
I just got the 7002 with my new subscription on the singnet fibre. Thing is, my new flat walls seem to be thick. Some 8m down the corridor and turn into my room, my signet from cellphone to the router at HDB default opennet point has dropped to near zero signal. Any remedy? Has it got to do with the ac network?
get another AP lor.
Ks1991
in additionally, my note 3 and note 10.1 2014 both only can reach 67mbps download and 108mbps for upload wirelessly.. while i heard other people can reach 100+ mbps on their htc one ! anything i need to tweak to achieve that kind of speed?
renfred89
The wireless channel plays a part. Bandwidth plays a part. Many factors affecting this.
However, i feel that note 3's capability is only up to this standard. If you are able to test out the performance directly beside the router, then thats the best a note 3 can perform...
Ks1991
man. yea, i was standing right beside of the router. such a shame considering htc one are having "older" specs than note 3.
anybody have any idea how to change the bandwidth of dsl7002GRV? heard from fellow bros that changing bandwidth will improve wifi speed:s13:
howdeepisyourlove127
Recently I upgraded my to Singtel 200mbps and receive Aztech DSL7000GRV I didn't know that the router wasn't dual band. The wifi speed for my Zen ultrabook Ux31 only cap 30 to 40mbps so does my Iphone 5, when use cable it can cap to 200 for upload and download.
I called 1688 & ask them change to Aztech DSL7002GRV Singtel CSO tell me I have to pay them to upgrade I was damn pissed off becos they are offering me DSL7000 which is a older version.
Anyone actually manage to change to Aztech DSL7002GRV without paying?
renfred89
Many people have gotten the 7002. You just need to be lucky enough to get it for free..
keigo22
Just sign up during those IT fair will do. Beside u got better deal during that period also.
Henry Ng
It is a IT show promotion that 7002 given to all fibre sign up. After promotion will be back to normal 7000. Must do homework la. 7000 is single band and not old model. Now is Pace router which is old model.
Henry Ng
Your note 3 wi fi signal week and specs is so so. To be fair, wi fi speed should be tested using a notebook with minimum standard notebook specs and at least 4 Gb RAM.
otake1982
Hi guys, I can't seem to find the specs for this 7002 router. Is it running on 802.11 g/n/ac?
I was going to get this repeater but not sure if it will work. The Repeater supports till IEEE 802.11n/g/b only...
WestGuy
No AC.........
renfred89
7002 is a dual band bgn router only.
renfred89
Latest firmware get pushed to my router after a sequential reboot.
Henry Ng
Should be the same as 7000 i guess
default Singtel Username and Pass...
Also this router is faster and better than Starhub's AC router. This is as the ac technology is 1 year old and it is harder to get through thick walls whereas the wireless-n tech, has the ability to reach a theoretical speed of 300mbps and is a long ranged technology which is easier to go through walls. With 50+ and a max of upto 200+ mbps on your router, this is as good as having a LAN cable
So that's it.
By default there is no User ID & password required unless u set it with a password protection.
