Battery replacement recommendation
tuntun
Hi,
anyone can recommend where should I replace my old models 6S and 7S? both are now 74% & 78% battery status and cannot last more than 4 hrs daily...
reddevil0728
Hi,
do you plan to use the phone long term after replacing? any other issues with the phones?
tuntun
yes plan to use for another 2 years for 7 plus and 6S for at least 1.5 yrs..thanks...so far no issue with phones except battery cannot last long...
reddevil0728
So there you go, you have answered your own question
Habrosus
I'd just go directly to Apple Store.
magix
Since you plan to use the device for the next 1.5-2 years. recommend u go back apple for battery replacement although price is high. But original parts
Either DIY or go to Apple.
If you can DIY, can go for Pisen extended battery. I installed one myself on my 6S. You will need to get screen adhesive too. Pisen is quite famous for their batteries but can be 2x more expensive than those no-name China brands. If you go onto YouTube there's even a guy that toured their factory.
Those cheap unofficial replacement, avoid at all cost, they get the cheapest batteries they can find and put it into your phone. Your iPhone explode, good luck
tuntun
where did you buy in Spore? or buy from aliexpress? Any shop selling pisen and installation together? Thanks
angelmiao
Hey guys, may i ask is it recommended to change the batt at apple store before warranty ends? Am using ip 11 pro, but starting April, i noticed that my max batt capacity been dropping 3%.
I'm planning to use the phone for at least another 2-3 years. :look:
reddevil0728
If you are willing to pay for it, you don’t have to change it before warranty ends, you can change it when the battery capacity decreases too much.
Because they wouldn’t suka suka change for you for free
70niner
Say for battery change with QCD, how long will it take? I don't have a spare phone at the moment, so would prefer the change to be completed within the same day.
My phone is XS
