Battery replacement recommendation
SibehHL
Say for battery change with QCD, how long will it take? I don't have a spare phone at the moment, so would prefer the change to be completed within the same day.
My phone is XS
I made appt for first slot in the morning for Jurong East branch and the whole exercise took 40-50mins including all the admin stuff. But note that was 1 year ago and phone is 7+
Morugana
should be $75 from apple
last time got discount at $38 due to CPU speed throttling scandal
Nakedtoes
Cpu throttling issue.. Apple replace for free leh.. But now no more
where did you buy in Spore? or buy from aliexpress? Any shop selling pisen and installation together? Thanks
I bought from Tmall official store and forward to SG. Installed myself. Not sure if there are stores here that offer Pisen battery.
ichinisan
How long does it take for the battery replacement at A.LAB Changi? Anyone did it recently?
Nuggette
I bought a PISEN high capacity iPhone X battery wanting to change it myself by now feeling not as confident. Anyone knows if there are any shops willing to change it for me? Willing to pay a fee for that...
anthonygreenisreal
Don’t think any shop wanna take the risk of changing an unknown third party battery which is not bought by them. You have better luck just purchasing and changing the battery from the shop.
paul02
Try your luck, a few might help you.
GGGGGG
Anyone has any idea if iPhone still covered in AppleCare, can bring in for free battery replacement at either QCD/ALAB/Apple store? Thanks!
GGGGGG
depends on battery health.
Thanks for your reply, so meaning only below 80% then they will change for you? I read from the Apple site it says:
If your iPhone is covered by warranty, AppleCare+, or consumer law, we'll replace your battery at no charge.
But again, not sure if there’s any other clauses or terms and conditions. Thanks again!
reddevil0728
Yea so if below 80% then FOC.
Unless got some other issue.
If not ppl will abuse it and demand for a change even at 99%
hereiam7788
Just change the battery at Apple Orchard. It is not too expensive given that it is original. Each change, can last u another 3 to 4 years easily.
Nuggette
Just to update that most shops will do it for you. Price range from $20-$40. I chose MisterMobile in the end since they are the closest to my house. Now keep fingers crossed that my higher capacity Pisen battery is indeed the real deal.
xelawtl
I used ezbuy ezship to forward.
No issues in shipping, just may require to use sensitive air or sea shipping.
May i know how much im total to ship to sgd? breakdown of each would be good. eg pisen battery type cost + ezbuy shipping + commission.
Went to tmal and the ip6s extended battery (2330mah) cost rmb399 = approx 79sgd.
apple standard 1715mah replacement at apple store sgd75.
worth it?
thanks for helping out.
reddevil0728
worth it?
tbh, nothing beats having it changed by apple if you are comfortable with the price.
If during the course of replacement, they encounter any problem and they can't fix it, they might very well replace the whole phone for you
worth it?
There are many different sellers out there. As long as it is from Tmall it should be authentic. I got mine for well below 200 rmb.
