Beginner guide for small investor
Hi, I’m new to investment industry.
Just open up the peoms accounts and DBS Vickers.
Planning monthly invest 10-20% of my salary.
It worth to invest with small money?
Or invest with certain amount of money(10k)will be good?
(To save the commission fee)
fr33d0m
Don't think too much about commission. It is only 1 - 2%. In the long run, it is almost nothing.
Toni90
How much your salary?
goldnut
Vickers is good only for local shares with cash upfront acc.
Overseas stock use Siao Char Bor. :D
Mergui219067
Start with SGX stocks, buy some REITs that you know & see around.
CapitalMallTrust, FCT, ShengSiong etc etc
financenewbie
actually ah, i just finished uni too.
Any other tips on what I should look out for? Planning to start small small, then hopefully grow to a sizeable amount by the time i hit 30.
Been looking at a lot of money blogs like seedly and moneysmart, but knn seems like a bit too much information for me to digest
dork32
20% of 3k is 600.
enough to buy 200 singtel shares. if you use cash account in vickers, two way brokerage is $60. it means that you singtel shares must go up by 30 cents to break even.
if you buy 3000 singtel shares using vickers cash account, two way brokerage is $70. It means that singtel shares must go up by 2.5 cents to break even.
dork32
for his case, it is going to 10%.
even if it is 1-2 %, it is terrible if other people are paying below 1%
Wishdom
Both posb and poems have a regular investment scheme which buys into a counter every month for cheap. Go check that out.
Sent from Ilovennp using GAGT
TabascoSauce
Protection first, but don't buy ilp or endowment.
Then build up habit of monitoring ur savings and expenses.
Set up high interest bank acc and find a suitable cashback card
Investment wise, spend more time to read up before committing
IamLWF
Better to understand before investing
Yes it's possible. There are a range of instruments that will take in such amounts. Common ones will be POSB's Invest-Saver where you buy into the STI ETF or a bond fund, Maybank KE's monthly investment programme where you can set a minimum of S$100 to buy into local stocks. Robo advisories like Stashaway (no minimum) and Smartly (minimum S$50) will also fit into this budget. All these are on a monthly basis.
As you are new to investing, may be a good idea to read up first. Books like Millionaire Teacher (local SG context), Intelligent Investor are great reads.
A lot of people ask about how to begin on the Seedly QnA platform. If you read the blog, can go check out the QnA also
