Best Basic Printer for Students
zjfsimple
for at home use. currently using Canon mp3000 series. like a lot of printers in this price range it is super mistake prone (printing on 2 pages at the same time), which wastes lots of paper, ink and time. Any recommendation that can make printing more efficient and less time consuming? Not looking for one of these expensive ones with too many functions, but a small upgrade will be acceptable :)
yusoffb01
i have been using epson l210 for more than 3 years. the one without scanner is 199 and you can use third party inks which cost $5 for 100ml and can print at least 1000 pages
people will say dont buy inkjet, the ink will dry up if you dont use and that is true if you dont print for a few months. but its a non issue because there is power flush function. until now i still print everything in color
dgenex
Using Fuji Xerox P265dw, Black Laser printer, not for colour printing but cheap and does the job well.
Parmesean
I would recommend the Brother HL-L2365DW. I personally use the color version of this printer. I've been using Brother Printers for years and swear by them. Even my Dad's office uses Brother printers.
LiLAsN
If you are a student that doesn't use the printer over a long period of time in between printing sessions, then laser printer is better. This is because, unlike inkjet, it won't dry up over time.
wwenze
Good one, bought the P255dw for less than $100 after considering the free NTUC coupons during an IT show, lasted for over two years. Needed the duplex.
nwh_sg
Using this printer, most heavily used by my daughter for printing notes in b/w. The auto-duplex is good in saving time, paper and reduce thickness of notes. It now has become a must-have feature if I need to get another printer.
The original TN-2380 toner can get at around $80 as well.
steven168z
i have a mono laser printer.
now sometime i need to print colour what should i do due to my child primary 2 work teacher say must have colour :s22::s22::s22:
not sure true or not..
if i print non colour, they shouldn't penalise the student. isn't it?
should i get inkjet?
bunnypangsai
Can always get laser printer, toner get those third party ones. :o
i have a laser printer.
tmfwy
I used these when i was a student
https://www.epson.com.sg/Dot-Matrix-Printers/c/w160#97H8w16OPLshHTUE.97
Printed out lovely ascii art :D
Seriously
Get a colour laser
I am using the Fuji Xerox CM305DF
Love the Auto Double sided printing
Cheap toner
Used the printer lopts when taking my vdegree and i never finished a set of toners before i graduated even with lots of PDF text printouts..
What i don't like is that it lacks double sided ADF. Scaning double sided pages is a chore...
steven168z
Seriously
Get a colour laser
Cheap toner
lol
The DocuPrint CM305 df is a high quality multifunction A4 colour laser printer especially designed to meet the documentation needs of small to medium businesses. Remarkably simple to use, it empowers any office with oustanding performance.
https://www.fujixeroxprinters.com.sg/en/Products/MultifunctionPrinters/DocuPrintCM305df.aspx
tmfwy
lol
I'm not joking about the CM305DF
Its the DOUBLE-SIDED COLOUR LASER PRINTING that is a boon if one needs to print out large volume PDFs for reading.
I swear by it when i chucked it 2 inch thick dockets for printing for presentation hand outs to each marker. No way i am gonna manual double sided print for it..
It is something that the mid-range colour lasers like the CM215 /225 cannot beat.
Scanning of docs produces crisp clear whites, which the CM215FW i had sucked at. The CM305DF scan quality, i give it 2 thumbs up both for text and images
i would say if one can convince dad to buy it as a family printer, it would be awesome ( awesome indeed if RPGs still used paper and dice to play ). :p
steven168z
https://www.qoo10.sg/item/FUJI-XEROX-OFFICIAL-FUJI-XEROX-LASER-PRINTER-DOCUPRINT-CM305DF/446538791
your house must be big
nwh_sg
Seriously
Get a colour laser
Cheap toner
Did you mean 'Cheap compatible toners'?:s11:
Rock-kun
Samsung used to be one of the cheapest. Last time I got a mono Samsung laser for only $99. And one of the few printers back then that actually worked on Linux driverlessly.
Now they are one of the costlier brands methinks.
