Best portable charger
chris888222
Currently using the valore one by challenger. 5600 neontube.
Okay la quite decent. Member got 30% off at that time.
palmtungsten
Using this energie portable charger and it is only 3000mah.. Ultra-portable. Output current is up to 2A and can charge tablet like iPad
berrytini
Using this energie portable charger and it is only 2000mah.. Ultra-portable. Output current is up to 2A and can charge tablet like iPad
May I know how much you got it for and where? How many times can it charge the iPhone?
palmtungsten
I pay $79 previously during IT show when the retail price was $99 then. Now you can buy it from major electrical store like challenger at $79.
On paper, you can charge 1.5 time. In reality,it is one full charge only
palmtungsten
S$79 for a 2000mah charger.... serious???????? Even the sony cost way cheaper. Cos it charge at 2A??
Just get a probox 5200mAh @ lesser the price.
PROBOX-Portable Power Pack with 5200mAh Li-ion battery
Simlim selling at S$48. Challenger sells the same thing @ S$6X.
Very serious.. But it is much smaller than Sony $29 charger and at least 60% smaller than probox battery battery.. physical size of portable battery does matter to me.. I can put this battery charger and iPhone in my pant pocket to charge iPhone if needs be..
I also have the same price but high capacity 10400mah Yooboo portable battery (pay $80).. This can charge iPhone 5 times or more but too bulky Liao and collecting dust now..only use it for oversea trip and love 2A USB charging port on this Yooboo battery charge..
I bring this ultra portable battery charger out very often as compared to Yooboo battery charger. It is portable and I use it more often due to its size and weight..
palmtungsten
Small can consider... but price is a hugh issue.
Totally agree..I had been thinking for a while before paying it for $79 price tag (retail price was $99 then).. Btw, wrong info given earlier it is 3000mah. Still expensive since most can get higher capacity and of course more bulky one at this price..
Sony 2000mah shall be good balance of value for money and size and weight..
gt_5454
The Sony one really looks like a good balance of value, size and weight. I'll go take a look at challenger one of these days. Does it include the iPhone 5 adaptor aka lightning cable head?
ragnarok95
Senior Moderator
Senior Moderator
Nope, the sony one came with just a normal cable for android. I am using it now. :D
melovelinux
Yoobao is a good brand.
dun really recommend sony.... over rated and hardy hold enough charge even on higher end models.
agree! got one time i use the cable from dat brand it charge my phone like 30-50 percent in 5mins when it was low on bat.
i lend cable from fren
let me know if you know wher can buy i want :s13:
anpanbun
I love its size. I can just slip it into my small purses.
How long does it take for a full charge? iPhone 5?
Some portable chargers are incredibly slow
