bsod error help
wizardmao
hi guys, previously kept encountering bsod error 3b, The error is a system_service_exception with stop code 3b. (STOP: 0x0000003b).
tried google but cant seem to find the cause for it and ended up attempted a reformat on 14th feb. all was good until minutes ago jus now it occured again.
would like to ask for help if anyone good with troubleshooting what exactly is causing this?
my pc specs are listed at right, and when the bsod occurs, usually i am not doing anything intensive. happened on many different scenarios such as while doing web browsing, while jus listening to music and stuffs only.
could it be due to faulty RAM?
koicafex
come in laugh at maomao :s13:
it comes and goes right
try installing the hotfix from microsoft
if not
try updating all your drivers to latest 1
wizardmao
:vijayadmin:
elite laugh at peasant also song.. :s22:
mai liddat leh here for troubleshooting only.. :(
simi thing comes and goes :s11:
moi pc 2 years+
the very first bsod started ard dec~jan2014 iirc
wizardmao
simi hotfix from microsoft? from windows update?
i recently reformat liao, drivers etc also install back etc, ran windows update also liao.
only havnt do hdd test, memtest etc all those cos i also no idea whats wrong to test :s22:
koicafex
your rig and my rig same same hokay
u got ssd somemore :sad:
jin elite...suan peasant
reseat your ram before ma?
aiya my pc also always bsod 1...
sometime 1 day bsod 5 time, then no bsod for next few months :s22:
some driver problem
wizardmao
reseat ish simi? take out blowblow a bit put back in right? tried. but always with 2 sticks. and same slot. havnt tried diff slot or with only 1 ram.
becos this bsod like.. not easily occur leh if i use 4gb ram only i also no idea mus use how long den sufficient to test if its alright or not.
chiur 1 audio hoot think can buy moi pc x 2 riao :s22:
chiur sho elite, can tahan bsod meh? moi dun like though, feel sibeh uneasy to know my pc will bsod :(:(
koicafex
blow sai la...gameboy izzit :s13:
go event viewer see the error message la
wizardmao
say liao, bsod 3b lor. month ago+ when it started occuring already tried to google for resolutions/fixes but to no avail.
tried to leave it hoping it will go but still once in a while have, irritated with it, went to format pc now still hav ish jin dulan :mad:
The computer has rebooted from a bugcheck. The bugcheck was: 0x0000003b (0x00000000c0000005, 0xfffff96000186483, 0xfffff8800a509030, 0x0000000000000000). A dump was saved in: C:\Windows\MEMORY.DMP. Report Id: 021814-9453-01.
koicafex
go try a older version of graphic driver lo~
i not using 560ti liao so i also dk which 1 stable :s13:
wizardmao
try liao, two years ago when buy pc ish use latest at that point of time, 285.62
cos moi got save older drivers in moi hdd in case need.
285.62 this issue also occur before.
i think could be ram though.
koicafex
ram bery hard spoil 1 reh :s13:
u go run memtest lo
doubt there's any prob
wizardmao
up for more replies first~
go koon for now :s22: whole night haben sleep
maybe wake up liao den do if need.
Alphas
caused by a faulty driver, look for the details, it could be network driver, graphics driver. It happened on my apple mobile device driver.
wizardmao
Can shed more light on where to look for this 'details'? I dun hav itunes installed yet.
koicafex
Told u driver problem Liao
U keep ask u think will solve problem?
wizardmao
driver problem, so many drivers how i know which and how to fix?
already update to latest drivers liao. although since the incident this morning till now havnt bsod but i also cant be sure its solved because it doesnt occur often mah and its totally random mah.
dun ask the issue also wont go off :s22:
commach
Change the default setting to small memory dump and uncheck the "Automatically Restart" as well. Nobody will bother to debug a full memory dump unless paid service, the current/default setting result in a memory.dmp which could be as large as 1⁄3 of the physical memory installed.
Dump File - Change Default Location - Windows 7 Help Forums
After you changed the setting, wait for the BSOD then upload the mini dump to any free-to-access file hosting site, provide us the link to download the dump for debugging.
wizardmao
will have to wait for next bsod(if any) before i can provide the mini-dump here.
btw, automatically restart means upon bsod after dump is created/generated, pc reboots itself right? by default i had it checked. however all of my bsod incidents regarding this issue, i had to manually force reboot otherwise it will only remain in the blue screen. is this normal? anyway, unchecked it already.
