Hi guys. Im new at building a PC but i tried. Sourced out these parts. These are for a 1.5k (+/- $100) gaming rig and wondering if there are any compatibility issues or if there are certain things i can improve on/omit. All these parts are sourced from Fuwell's price catalog that i happen to have at hand. I'm wondering if i can get a cheaper price somewhere else? All advices are greatly appreciated, thank you!
MOBO: Asrock H97 Killer
CPU: i5 4590
CPU Cooler: (Still unsure)
HDD: WD Blue 1TB
RAM: G Skill Ripjaws 1866mhz CL9
GPU: Gigabyte R9 380 G1 Gaming 4GB
CASE: Corsair Graphite Series 230T
PSU: Corsair CX600M Modular 80+ Bronze
DVD: Samsung SH-224 24x DvD+-RW
OS: Windows 7 Home Premium 64-bit
Hmm.... how about this? Take it with pitch of salt..=)
CPU + MOBO: i5 4460 + Asrock B85M-Pro4 - $373
CPU Cooler: No need - no overclock
RAM: Corsair Vengeance 1600MHz CL9 (8gb DDR3) - $99
GPU: Sapphire R9 380 Nitro 4GB Dual-X GDDR5 - $365
SOUNDCARD: Creative SB Z Model SB1500 - $149
SSD: Samsung 850 EVO 250GB SSD SATA3 - $169
HDD: WD Black 7200rpm - $108
CASING: Corsair Graphite Series 230T - $119
PSU: Seasonic X Series 650W Modular Gold - $169
Total: SGD$1551 from Fuwell
Suggestions aside....
Nowadays, seems that PC upgrades can get obsolete quite fast.. high end specs get outdone within 3yrs or less.... =(
IMHO... overclocking is just to get that extra fps in the game.... for normal surfing, internet uses... overclocking is not necessary..
GPU depends on your choice and budget...
Soundcard is definitely optional as onboard sound also does the same job...
You have good soundcard but shitty speakers is also no point...
I would say having a SSD is definite must-have... be it booting up speed of Win7 or loading of games...
As for HDD - you can go for WD Blue - sufficient for normal usage...
As for PSU - dun save money on it... get as best as you can... of cos not 1200w type... IMHO....600w or more should be more than enough...
Hope it helps...
To get the most information, go this thread -
http://forums.hardwarezone.com.sg/h...entry-level-systems-part-2-a-3396832-595.html
