Building a gaming rig, need some help!
Goodshot
i kinda feel impatient to wait for skylake also :s13: i got the R9 because i had discount for it and fingers crossed will be just as good as gtx 970
The r9 390 is designed surpose to better than 970 , i hanvt got the chance to test it .Reading from reviews they both perform the same , maybe some game Amd might better
MoneyFace =p
i got the r9 390 online because i had discount for it ($509). Saw the PSU requirement when i received it today, got the worst shock of my life (750w min.) i don't feel like getting a stronger PSU because its very expensive, but what if i used a PSU lower than the required power?
A 600-650W good quality PSU will suffice.
solaryzed
Won't spoil de... unless you force your way though,besides plenty of tutorials on YouTube ma.. my first rig building also without experience and just did fine ma. Hmmm I bought 2 strips of 15cm can brighten the whole pc liao, like those you see in other threads.
haha is it really easy? i watch a lot of videos, they always confuse me with the different names of the ports, wire names and all.
does the 2 led strips replace any wires in the pc kind?
MoneyFace =p
Okay guys, i came up with another set! Hopefully it is nice!
CPU + MB: Intel Core i5 4460 + Asus H81 Gamer $394
GPU: MSI R9 390 Gaming 8GB (Self Owned) $509
RAM: Corsair Vengeance 1600mhz 2x4gb CL9 $99
PSU: Seasonic G Series 650w/750w $145/$179
SSD: (Self-owned, Transcend 128gb) -
HDD: WD Blue 1 TB $75
OS: Microsoft Windows 8.1 Pro from g2a $33
Casing: Any recommendations? Would like one with a window.
Total: $1255. All PC Themes Prices.
Also, is there any tips on those fancy pc with lighting inside? would be great if someone can recommend me some cheap but good monitors also haha
P.S Is there any assembly services in Sim Lim? Do i have to pay?
Sharkoon T28 already comes with a side panel window and 3 bling bling LED fans...
hengheng220
Yes very easy... if anything just read the motherboard instructions is like playing lego. Anyway... the case that MoneyFace recommend is the same as the one I'm using. This is my case with 2 strips of leds 1 year ago lols
Sent from Samsung SM-N910G using GAGT
k8118k
CPU : 6700k
Mobo : Please advise
GPU: MSI R9 270x 2GB
RAM: Please advise
PSU: AX860I
SSD: 850EVO 250GB
OS: Win 10 Pro
Casing: H440
AIO : Fractal S36
Please advise mobo and ram to achieve 5ghz overclocking.
MoneyFace =p
CPU : 6700k
RAM: Please advise
PSU: AX860I
SSD: 850EVO 250GB
OS: Win 10 Pro
Casing: H440
AIO : Fractal S36
No point if your CPU lottery get you a cui CPU. :s22:
You are spending money on the wrong things for wrong reason.
Want 5 GHz? You'll find more chance with Intel Sandy Bridge or AMD Vishera.
Goodshot
Ya some ppl upgrade part by part , 1 shot buy all heartpain
avsquare
CPU : 6700k
RAM: Please advise
PSU: AX860I
SSD: 850EVO 250GB
OS: Win 10 Pro
Casing: H440
AIO : Fractal S36
5GHz on Skylake? I think you need a lot of prayers :s13:
Kapish
step by step?
might as well save the money and get a better gpu
at least you get a good gaming experience right now and no need to wait till later. until you reach a bottleneck which is unlikely then you upgrade to a better cpu
Jian19
wad will be ur usage on new pc ?
i suppose u going to reuse ur gpu and ssd
i5-6600k + Asrock Z170 Pro4 ~ $555
Corsair LPX 8gb ddr4 ~ $130 / Kingston Value 8gb ddr4 ~ $99
Superflower leadex 650w ~ $139
Fractal Design R5 ~ $159
CM hyper 212 ~ $57 / Corsair h100i GTX ~ $160
$1040/$1200 buy and assemble @ mynextcom/Bizgram ask for discount.
k8118k
then no need 5ghz lo.
try my best to buy and archieve as high as possible.
4.5Ghz also ok wan...
