BUILDING BUDGET RIG FROM SCRATCH
Lex1989
Expert please advise on the compatibility and budget/sourcing of items.
LAZADA : $1051 (After discount $901.3)
Corsair Carbide Series Air 540 High Airflow ATX Cube Case SGD 189.00
FILCO Majestouch convertible 2 - Brown Switch SGD 269.00
Swanspeakers M10 2.1 Multimedia Speakers (Black) SGD 129.00
Sapphire Dual-X R9 280 3GB GDDR5 OC with Boost (UEFI) SGD 285.00
Crucial MX100 256GB SSD SGD 179.00
TRADEPAC : $531 (How much discount will tradepac give?)
ASROCK H81M – HDS + I5 – 4460 SGD 294.00
CRUCIAL DDR3-1600 CL11 SGD 78.00
FSP Aurum S 500W [80 Plus Gold] SGD 89.00
Western Digital Blue 1TB SGD 70.00
DELL ONLINE : $359 (Any places where I can get cheaper?)
Dell UltraSharp 24 Monitor – U2414H : SGD $359.00
Estimated cost in total : $1800
mdhasan
Bro, I heard the mobo + cpu combo price is only valid if you buy a complete system from them. So you might need to check the actual pricing from them. They might quote you upto $50-60 more as you are not buying whole system from them. So check with them before you go SLS.
Sent from Zenfone 2 using GAGT
nippp0n
You can consider going for Filco Majestouch 2 @ $189
Top up $14 more for Sapphire R9 285
Add additional $20-40?
PC Themes is selling this monitor at $329
Comments in red.
Mikiberry
How many GB is this @@ - I think you should follow nippon for the commented parts and place the cost savings on a better GFX card like 970 or 290x.
Your casing is a little too expensive, go for R5 instead which is much cheaper.
Lex1989
Comments in red.
Thank you bro for advise.
I will take into consideration of the 2 models of the filco keyboard.
Which is one with bluetooth and non bluetooth. (correct me if im wrong)
As for the GPU, i will do some search to compare before making any decision.
Lastly will go with PCtheme for the monitor.
Thank you very much!
Lex1989
Thank you for advise as well.
Will try to google regarding such GPU 970 and 290x.
as for the RAM i plan to get a single stick 8GB. which recommended by many.
As for casing, no choice. hahaha i love it.
